SideShifter Tri-Carb
Gearbox question. I have a laygear (AEC3616) with I assume rounded teeth. Can I use the first gear assembly AEC3566 (8G3013) which is noted as having chamfered teeth here: <a href="https://www.ahcso.com/pdfs/gears_part_numbers.pdf
" rel="nofollow" target="_blank">reference table for Healey Gearbox part Numbers</a>
The part number for the 1st gear assembly on some resellers sites shows it to fit earlier years; including 100-6. Confused, is this a replacement part for "when supplies are exhausted" that will interchange with the earlier laygears?
