64rocksprite
First off - Hello to all. I have been just reading and digesting all the info so far.
I'm in the process of re-restoring my '64 MkII. The car was bought new by my Dad, and I began restoring it when I was 13. Finished my senior year of HS, drove it ~2K miles and parked it when the speedo cable broke..went off to college and left it in his garage.
Present: Now in my garage and I drained the gas tank (put it away "wet" in 1991...I removed and cleaned the fuel bowls (ugh) and sprayed gumout into the carbs liberally.
I got it to start, but the idle is rough, without opening the throttle, but working the choke a little, it will run, but it tends to go from a barely running idle, then without warning, it revs above 3500 almost 4 or 4.5K rpms..at which point I am moving as fast as I can to get to the ignition switch to shut her down..
So..what you guys think? I took the fuel pump off, disassembled and cleaned. It seemed OK once cleaned. I am guessing I need to bite the bullet and tear the carbs down.
Any other ideas in case it is still doing this after the carb cleaning?
Sorry for the long post..
