M
Member 10617
In order to adjust the valves, I know that I have to rotate the crankshaft by hand. Years ago with American cars I was able to do this by turning the fan, but with a plastic fan on my TR3, this is not possible.
I understand that the normal procedure is to use a wrench to turn the crankshaft end nut. But I don't see one on my engine.
What is the best way to rotate the engine for this purpose? All the literature and videos simply say: rotate the engine clockwise, but none tell you exactly how this is done (they assume you are born with this knowledge, I suppose).
Also: I read that there are two strong opinions on whether or not to remove the spark plugs to facilitate this process. Most warn against it.
Hi Guest!
