From all the many discussions I've seen over the years about these kits, my conclusion is that they are, at best, a band-aid fix. Consensus seems to be that any lack of lubrication in that area is as likely due to wear, clogged or blocked oil passages, etc., so simply feeding more oil from an external source (and possibly robbing that other source of needed oil and pressure) is NOT the solution.bunzil said:This is an important thread since so many are buying these kits to improve oil pressure up top.
Is it necessary, beneficial, or not?
Brosky said:If I do go to new roller rockers when I swap out my head,
ALLAN said:The TR6 has never had enough oil to the top end and with a motor in good condition has more than enough oil pressure to feed the aux. oil line with no problems (you do need good valve guides and seals). -----I had a baffle welded to the inside of my alloy cover, it is a 1/8" x 1 1/4" flat aluminum plate running along the inside of the cover stopping short at both ends of the cover by 3/4", this allows the engine to vent without blowing oil out, it made a big difference.
tomshobby said:I am installing an auxiliary feed. I have also wondered if it might help lube the cam and lifters. I know the cam lobes and lifters pretty much depend on oil from the bottom end, but more on top might be helpful.
tomshobby said:I will also have valve seals. But I am installing new bronze guides, both from Goodparts. As I understand, the original guides depended on the lead in the gasoline for lube. Since there is no longer lead in the gas there is no longer lubrication unless they get oil from above. And if there is sufficient wear in the guides there will be plenty of blue smoke and oil in the intake (blow-by helps too). The 70's GM v-6's were notorious for this to the point of filling the air cleaner with oil. The bronze guides supposedly address this problem.
