Rocker shaft rebuild
BOBBYR
Hi Guys,
I got my parts in from Moss today so I thought this weekend would be a good time to find out if that's where my oil pressure is going.I was wondering,how many of you have rebuilt a rocker shaft?With the right parts it looks pretty easy.Is there anything I should beware of before I get into this?Like I said,I have to test it first but alot of you seem to think this could be the problem.All help is appreciated.
Bobby R
Dave Richards
If you ordered parts to rebuild the rocker shaft assembly, were the parts in white boxes?
BOBBYR
BOBBYR
Hi Guys,
I've only bought a valve cover gasket up to now.I just wanted to lift off the valve to see if the rocker shaft is pouring out too much oil.I want to be able to close up this engine as soon as I get done testing.If I need a rocker assembly I would like to build it myself so I guess I'm looking for who would be the best supplier of parts as far as quality.Let me know what you think when you get a chance.Thanks for your help.
Bobby R
TimK
There are others much more expert than I am, but I sent mine away to be done because each of the pedestals has to have the bronze bush removed and a new one installed, then reamed to fit the new rocker shaft. Unless you're set up for this type of machining, I wouldn't try it. I'd check out Healey Surgeons in Maryland to have this done. My rocker shaft was worn badly on the bottom -- big grooves--and oil poured out from the pedestals and there was a lot of blue smoke in the exhaust from the valve cover breather that goes into the carb. With valve cover off, there will be geysers of oil spraying all over if the shaft is worn.
I just remembered, what the vendor did was use an oversize rocker shaft and reamed out the existing bushings to take the new larger shaft.
GregW
Option B: Don't rebuild, get a new roller rocker assembly. This is a higher ratio 1:1.55 from Rocker Arm Specialists mentioned in your other thread. They have a 1:1.5 also, which is closer to stock.
steveg
I used the 1.6 from Rocker Arm Specialists with no problems other than a need to shim the banjo oil fitting with a couple of extra copper washers in order to give clearance over the rocker itself.
Be very careful of the banjo bolt--they strip easily.
Pictures at https://www.pbase.com/stevegerow
TimK
I'm sorry I don't remember. I was trying to fix the blow-by (blue engine smoke out the tailpipe.
John Morralee
quick tip re. banjo fitting : after 'hours'of trying to screw it back together and not strip I loosened all the rocker hold down bolts which allowed the the assembly to move, the banjo self aligned, went in easily, the hold down bolts could then be retightened.I used a professionally rebuilt part exchange assembly: the beneficial result to both oil pressure and consumption have been quite remarkable -- and no more smoke out the back on start-up.
BOBBYR
BOBBYR
Hi John,
Thank you for your response.I haven't gotten the time to get into this rocker assembly yet.When you get the chance, could you let me know where you bought your rocker assembly.I appreciate your help.
Bobby R
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
WHT Rocker Arm Shaft Replacement Austin Healey 21
G Installing New Rocker Shaft Assembly Austin Healey 3
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
D MGB MGB rocker shaft shims MG 1
JimLaney Rocker shaft plug/screw delima Spridgets 3
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
M TR6 rocker shaft install tr6 Triumph 2
KVH TR4/4A Rocker Shaft Lubrication, and Issue with Push Rods Triumph 1
S TR2/3/3A Bolting the rocker shaft Triumph 3
J TR2/3/3A Installing new rocker arm shaft. Triumph 6
DornTRoriginal General Tech Where is the Rocker Shaft Retainer Pin Triumph 2
TR6BobNF TR6 TR6 Rocker Shaft Assembly Triumph 1
B Rocker shaft spacing washers. Austin Healey 2
M TR2/3/3A TR3 Steering box rocker shaft and drop arm Triumph 5
glemon Final Rocker Shaft Question Triumph 5
glemon Tuftrided Rocker Shaft Triumph 3
glemon Opinion/Experence Rocker Shaft Wear Triumph 6
rlich8 "Oil Screw" on Rocker Shaft Triumph 6
ekamm TR2/3/3A Tr3 steering rocker shaft bushing Triumph 1
6 more about the rocker shaft Triumph 12
6 rocker shaft Triumph 3
L Rocker Shaft Assy Triumph 7
7 rocker shaft Triumph 2
T Defective rocker arm shaft photo Triumph 12
T Rocker arm/shaft question Triumph 13
H Rocker Shaft assembly Austin Healey 1
chicken Rocker shaft Austin Healey 3
B Rocker shaft problem Triumph 2
T Rocker shaft cleaning Triumph 19
Moseso Rocker shaft dis/reassembly Triumph 3
Tinkerman TR2/3/3A Locking screw on rocker arm shaft, TR-3 Triumph 4
D Oil Spraying from Rocker Shaft - BJ 8 Austin Healey 10
M Rocker arm shaft question Austin Healey 11
Tinkerman 60 TR 3 post 60000 Rocker Shaft Pedestal Bushings Triumph 2
C Rocker arm play on shaft Austin Healey 12
M Rocker Arm Shaft Triumph 4
S GT6 GT6/TR6 rocker shaft oil problems. Triumph 5
Y TR6 TR6 - Secondary oil feed to rocker shaft Triumph 12
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
Hamish Racing General TR Rocker cover identification please. Triumph 2
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
H Rocker Cover Data Plate Austin Healey 15
