Rocker shaft cleaning
T
Tinster
How difficult a project is removing and cleaning out the crud
from the horizontal pipe, inside the valve cover, that the
valve rocker arms attach to? My very first valve gets no oil.
No valve rocker arms got any oil until I poked the crud out
of the tiny oil weep holes in the arms.
1. Is this cleaning something a non-mechanic can accomplish?
2. What is the Rule of Nine? for valve adjustments?
Thanks as always,
tinster
DNK
Tinster said:
2. What is the Rule of Nine? for valve adjustments?Thanks as always,tinster
Always drink 9 beers before any work on an LBC
Brosky
Dale,
What horizontal pipe are you talking about? This was my head as we were adjusting the valves after installing.
Do you mean the horizontal rocker shaft itself? If so, you can lift that and take it apart and as long as you replace everything exactly as it came off, you should not have to adjust the valves.
And if you ever need to adjust them at some point, I will send you the simple procedure from the TR6 manual in a pdf if you need it. My thoughts are that you do not need to, nor should you in the foreseeable future.
TR674
Tinster
did my valve stem disintegration scare you?????
The rocker assembly is very easy to get off and clean. I don't have my Triumph Maintenance manual here in the office but I can scan the relevant pages for you if you like?
The mechanic called me this morning and my head is all fixed and clean. He is having trouble getting hold of the 5/16" stainless steel caps. His usual supplier has run out. Drat. I'll still be able to re-assemble the head over this long weekend and put the caps on later (no driving).
Regards
Craig
TR3driver
Great Pumpkin - R.I.P
I don't think you'll have any trouble at all, Dale. And I would definitely recommend it if you have a rocker that isn't getting oil. Basically remove the shaft from the engine (complete with rockers), then drive or pull out the pins that hold it together (not sure offhand if your TR250 motor will have cotter pins or solid pins) and the locking screw in one of the pedestals. At that point you should be able to clean out the inside of the shaft; but I would also remove all the rockers (which means removing the pedestals as well) so they can be cleaned and inspected as well.
Keep everything in order and put it back the way it came apart; pretty easy. I'd call it two wrenches. A drop of blue Loctite on the locking screw is a good idea, IMO.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]2. What is the Rule of Nine? for valve adjustments?[/QUOTE] Well, first of all, for a 6-cylinder Triumph, it's the "Rule of 13". "Rule of 9" is for a 4 cylinder.
Basically it states that, if you number the valves in order from 1 at the front to 12 at the rear, then the number of the valve that is fully open and the number of the valve you can set now always add up to 13. IOW, if valve #1 is fully open, you can set valve #12. If valve #6 is fully open, you can set valve #7. And so on.
Personally, I prefer a different rule; which lacks a catchy name but I find easier (and it works on any 4-cycle engine with an even number of cylinders). Just turn the engine until both valves for a cylinder are moving at the same time, then set both valves on the cylinder that is opposite in the firing order. You can even use the distributor cap to give you the opposite cylinder, just follow the wire for the cylinder with both valves moving back to the dizzy cap, then skip directly across the cap and follow that wire to the cylinder you should be working on.
70herald
Dale, for a person as organized and methodical as you are, this is an easy, one evening job. However if you are going to go to the trouble of taking the rocker assembly apart, order a new rocker shaft and just replace the old shaft. Since the oil holes are all rather small, there really isn't any good way to "scrub" it out unless you have access to a large ultrasonic cleaner. You could try forcing some sort of solvent in, but I would suspect that there is enough wear on the shaft in any case that it just isn't worth the trouble of trying to clean it.
After you take the rocker assembly out of the engine, there is a cotter pin at one end, and a screw that have to be taken out. then basically you just wiggle all the bits off and wiggle them onto the new shaft in the same order.
Before you order anything, take a look at the current parts to see if any of the springs are broken etc. Also, the part of the rocker which pushes the valve down may be worn. If so, it is very difficult to set the valves accurately. On my engine they were really gone. Happily I had a second complete rocker arm set up so I was able to scavenge enough semi decent ones and with a bit of polishing was able to smooth the pads out nicely.
the rule of nine is just a simple trick to help remind you which rocker arm clearance you are supposed to be adjusting.
T
Tinster
Thanks all,
Yisrael, I have had much bad luck purchasing new
aftermarket parts made in India or China. Does anyone
have a source for this rocker shaft other than the usual
Big Three?
I have had decent luck refurbishing old British pieces.
Most of my new India/China pieces have been junk that broke soon after purchase.
So, where can I source this rocker shaft?
thanks,
dale
angelfj1
Dale: The rocker shaft was used in many 6 cyl. TR engines. You have a good chance of finding a NOS shaft. Check Ebay and do a Google search for NOS TR parts.
Good luck, Frank
billspit
Basically it states that, if you number the valves in order from 1 at the front to 12 at the rear, then the number of the valve that is fully open and the number of the valve you can set now always add up to 13. IOW, if valve #1 is fully open, you can set valve #12. If valve #6 is fully open, you can set valve #13. And so on. [/quote]
You need to work on your math. Valve #13?
T
Tinster
Thanks Franka nd all-
I'll bid on the Ebay shaft and if I win it, I will
attempt to refurbish it. A good learning experiece
for me. If I am able to accomplish this task, I'll
refurbish the shaft in my car.
Am I correct that I should have my timing groove and the timing arrow in straight alighnment when I pull out the
rocker arm shaft? That will leave my engine at the proper
orientation to begin resetting the valves? I think?
Should I powder coat the rocker arms to make them last longer??
thanks again,
dale
swift6
thanks again,
dale
Its not totally necessary to have the timing marks match up but it might be easier to start the adjustment process. That could be up to you.
Don't powder coat the rockers. The bushing area and the tip are the only places they wear out. Powder coat won't increase the longevity of these pieces. Generally, you don't want or need to powder coat anything inside the engine that normally sees oil.
TR3driver
IMO the only way to go is to send yours (or a spare from eBay) off to
Rocker Arm Specialist
19841 Hirsch Court
Anderson, CA 96007
Tel (530) 378-1075
fax (530) 378-1177
mailto:rocker@c-zone.net
https://www.shastacounty.com/rockerarm/
Their prices are very reasonable (they charged me about the same price as I would have paid just for the parts needed) and their work is outstanding. The rockers literally looked new when I got it back; and the shaft, bushings, adjusters, locknuts, springs, etc. <span style="font-weight: bold">were </span>new.
Rickc
Dale
IMHO if you remove the rocker "gear" then you MUST re-adjust the valves .010". The procedure is so simple, it is not worth taking a chance on not setting them. I have a procedure that says it all.
Have fun
Rickc
TR3driver
Thanks, Bill.
Rickc
Dale
wish to add the following comments.
First there is absolutely no need to set at a timing position when removing the rocker assembly. The only consideration is it might take a few more turns to get to my starting point. Funny, never thought about seting it at a certain timing point.
Fully agree, no powder coating.
Thinking about math makes me dizzy adding one number to another might get you to the point of saying "OK which one is valve 13?"....sorry just had to add that one in:smile:
Using my procedure takes little grey matter effort and you are not jumping all over the place( turning the fan many many times).
Rickc
70herald
thanks again,
dale
Aligning the timing grove etc is something you would do if you were removing a timing chain / belt etc anything where the relationship between the cam and the pistons could change. taking off the rocker will not affect that at all.
Do not under any circumstance powder coat parts which are going INTO the engine. little bits which chip off wear off etc will not be good for the precision moving parts.
70herald
angelfj said:
Dale: , Item number: 280192246755
The rockers have been bushed with #660 bronze alloy and re-faced.
In order to bush the rockers, they have to be reamed out a fairly significant amount and there really isn't allot of excess metal there to start with. Sound to me like this is going to significantly weaken the rocker arms.
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
WHT Rocker Arm Shaft Replacement Austin Healey 21
G Installing New Rocker Shaft Assembly Austin Healey 3
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
D MGB MGB rocker shaft shims MG 1
JimLaney Rocker shaft plug/screw delima Spridgets 3
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
M TR6 rocker shaft install tr6 Triumph 2
KVH TR4/4A Rocker Shaft Lubrication, and Issue with Push Rods Triumph 1
S TR2/3/3A Bolting the rocker shaft Triumph 3
J TR2/3/3A Installing new rocker arm shaft. Triumph 6
DornTRoriginal General Tech Where is the Rocker Shaft Retainer Pin Triumph 2
TR6BobNF TR6 TR6 Rocker Shaft Assembly Triumph 1
B Rocker shaft spacing washers. Austin Healey 2
M TR2/3/3A TR3 Steering box rocker shaft and drop arm Triumph 5
glemon Final Rocker Shaft Question Triumph 5
glemon Tuftrided Rocker Shaft Triumph 3
glemon Opinion/Experence Rocker Shaft Wear Triumph 6
rlich8 "Oil Screw" on Rocker Shaft Triumph 6
ekamm TR2/3/3A Tr3 steering rocker shaft bushing Triumph 1
6 more about the rocker shaft Triumph 12
6 rocker shaft Triumph 3
L Rocker Shaft Assy Triumph 7
7 rocker shaft Triumph 2
T Defective rocker arm shaft photo Triumph 12
T Rocker arm/shaft question Triumph 13
BOBBYR Rocker shaft rebuild Austin Healey 10
H Rocker Shaft assembly Austin Healey 1
chicken Rocker shaft Austin Healey 3
B Rocker shaft problem Triumph 2
Moseso Rocker shaft dis/reassembly Triumph 3
Tinkerman TR2/3/3A Locking screw on rocker arm shaft, TR-3 Triumph 4
D Oil Spraying from Rocker Shaft - BJ 8 Austin Healey 10
M Rocker arm shaft question Austin Healey 11
Tinkerman 60 TR 3 post 60000 Rocker Shaft Pedestal Bushings Triumph 2
C Rocker arm play on shaft Austin Healey 12
M Rocker Arm Shaft Triumph 4
S GT6 GT6/TR6 rocker shaft oil problems. Triumph 5
Y TR6 TR6 - Secondary oil feed to rocker shaft Triumph 12
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
Hamish Racing General TR Rocker cover identification please. Triumph 2
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
H Rocker Cover Data Plate Austin Healey 15
