TR2/3/3A right to the wheel well
sp53
The PO on this project bolted a roll bar right to the wheelwell by using some steel plates and drilling two 7/16 holes for the attaching bolts.The roll bar was gone, but the holes are still there. I want to plug the holeswith a smooth sealing finish on the wheel well. One thought was to cut someplugs the size of the hole and butt weld those in place then seal them withsome body glaze and paint. I am a loss about making the plugs. I could cut themwith snips, but they are small. Any suggestions out there?
Geo Hahn
I'd cut plugs roughly to (polygon) shape with whatever you have handy - even an angle grinder or cut-off tool would do. Then I'd finish the exact shape on the grinder.
But then my 'machine shop' are generally the cut-off tool and the grinder.
What size are the holes?
M_Pied_Lourd
Weld in some washers...fill in the center with weld. Grind them flush
Cheers
Tush
TomMull
Cheers
Tush
Quick and easy and will provide good results. The washers might be a bit thick though. I've done the same with a hole saw and a piece of 18 ga metal. Use a drill press and you can even omit the pilot hole.
Tom
TexasKnucklehead
When I was doing my metal repair, I found it easier to cut the hole until it had square(ish) corners. A file or cutting wheel on a dremel will square-out the round hole. It's much easier to cut a square of steel slightly smaller than the hole. A magnet can hold the little piece in place to tack weld it into position. I found if the "plug" of steel were a little smaller, it took much less grinding after welding the seam. -But my welding skills are better appreciated because of how well I can grind.
If you weld washers, be sure they are steel and not coated -most are zinc coated and the fumes from welding are dangerous.
DonP
Ironic, I just bought a roll bar for my '62B, minus the backing plates and Grade 8 fasteners.
Now I'm figuring out how to fabricate the plates for that exact curved area.
Haven't drilled the mounting holes yet. If only I could borrow yours, we'd both solve a problem.
TR-3rg
Hi, Where did you get the roll bar from?
RG
DonP
A shop in Kansas that was clearing out their back room. It came out of a TR-3 they scrapped for parts. Nobody thought to save the backing plates when they pulled it out, but that's not a rocket science level challenge. A couple of pieces of 1/4 inch steel welded together for each plate and a slight bend for the wheel wells, doesn't have to match the curves perfectly.
S
sp53
On this roll bar they just tightened the bolts down and that force a kinda of squared out spot for the roll bar on sheet metal of the wheel well. When I first came across the issue of repairing the holes, I planned to skip it and use some larger outside square patches then double up on some foam padding for the wheel well covers and just try to hide the damage under the upholstery work. Now that I have gained some experience, I decided to smooth plug the holes and get the car back to original with the wheel-covers glued right to the wheel well.
Pounding out the metal was not too difficult after gaining some experience, but welding a 7/16 holes has been a challenge. I tried the washer idea, but just could not get it going. Perhaps I had a poor ground. I did grind off the finish? Anyways I cut some plugs with snips then ground them true and welded them in with the MIG. This time I use some copper pennies taped on both sides in place to bridge the hole plus get a better ground, and got it.
Back in the 70ites I worked for this sheet metal shop on gutters and downspouts that we soldered at the ends, corners, and outlets. We put on miles of that stuff and that experience comes in handy. In the future, I might try using more soldering because the MIG is difficult in those little areas.
CJD
Looks good, Steve! Those little holes are the worst...as much work as the big holes, but they are...little.
T TR6 grinding right rear wheel Triumph 22
Mio Rubbing noise from right rear wheel Spridgets 14
tahoe healey drip at right rear wheel Austin Healey 17
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
G Right-Side Shock Weeping Oil Austin Healey 1
C MGB Which Weber DGV is the right one. MG 14
P Jag XJ8 starts but then dies right away. Jaguar 4
Popeye General Tech O/D right angle drive choices Triumph 10
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
BritBite Speedometer Right Angle Drive Austin Healey 5
drooartz General MG Surprisingly enough, I was right! MG 7
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
C TR2/3/3A Right oil Triumph 8
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
TRclassic3 TR2/3/3A Body leans to right side Triumph 10
red57 Steering not right Austin Healey 66
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
dougie Big Healey Six - Used the Right Way Austin Healey 5
John Turney The Panhard Rod is Supposed to be Straight, Right? Austin Healey 7
Bayless What are symptoms of steering rack not shimmed right? Spridgets 14
T For Sale GT6 Mark II Right Front Fender - NOS Triumph Classifieds 0
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
C Left to right hand drive Austin Healey 2
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
Rut TR4/4A Nice project for the right person Triumph 0
JPSmit Fuek Tank Sender - does this seem right to you? Spridgets 3
D BJ8 pulls right on hard braking? Austin Healey 4
Simmo TR6 Right Hand Drive Conversion Help Triumph 3
Jim_Gruber 13" Tires - What's out there right now Spridgets 21
Popeye TR4/4A Seats - left/right Triumph 8
TomMull Post-War Other Herald 13/60: I didn't get the battery tray quite right Triumph 4
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
Simmo TR6 Right Hand Drive conversion Triumph 5
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
Zimmycobra TR4/4A Who's right - float height on ZS 175CD? Triumph 5
M TR2/3/3A Engine does not shut off right away. Why? Triumph 8
spartan0199 BT7 Right Front Brake Drag Austin Healey 30
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
Got_All_4 TR2/3/3A 2 questions; raising the body and taking out that lean to the right Triumph 12
Jim_Gruber NOS 10 Post BE Windscreen on E-Bay right now - NFI Spridgets 3
S TR4/4A water pump doesn't feel right Triumph 2
W TR2/3/3A '56 TR3 St 15000+ should have disc brakes... Right? Triumph 33
P T-Series TD Door Hinges: just what is the difference between right and left? MG 11
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
trrdster2000 GT6 Where to find the right tire? Triumph 8
5 Right Up Our Alley Spridgets 0
