Scott_Hower
FWIW, the replacement bead as supplied from BMIHT/Heritage is crowned as in Doc's car. So were the new Heritage front fenders (the 6in section where the fender meets the windscreen/scuttle.
This is a MAJOR PITA to replace a damaged /rotted section; cannot imagine doing an entire fender worth. The whole panel needs to come off, as it has a 1 inch tab under the folded bit that gets sandwiched/spotwelded between the panel seams. Ick.
