When posting a classified ad, you MUST select a prefix from the drop-down next to the subject line. If you don't you will get an error and your ad will not be posted!
I rebuilt one myself out of junk parts from 3 different boxes. Its a very simple transmission and as long as assembly is correct the only bad outcome you should expect is a noisy box. That's what mine is but I'm sure its only because once gears are worn in they don't like to be changed. I know the clearances are correct and the bearing's are new but driving across a shopping center parking lot in low is a little embarassing. Noisier than most.
Thanks for the replies...I just saw this in their catalog and didn't realize they sold ribcase transmissions. I don't need one since I have plenty of good ones including my 5 speed.
Rut
