Resource for Steering Pinch Nut?
Like Bill, I too had a problem with the new coupler. I think I stripped at least 2 bolts putting the new one in. Talked to the folks in Pa. and they said I had the correct one and to compress it. It is still unhooked in the garage. As I have stated in the past a poly one would really be nice. Just harshen up the steering a little.
The trick with the flex coupling (TRF Blue Book Plate DH11 Part # 150696 Steering joint),is to wrap a large hose clamp around it, and tighten until the bolts line up. BritBox is right, not a crack but a slit for clamping to the upper column.
