TR6 Replacing the IRS u-joints on a TR6
6TTR3A
Any tricks/pitfalls involved with changing out the IRS u-joints on a six?
I'm comfortable working on sidescreen Triumphs, but I've never
been under a six.
A friend asked me to help him with the job but I have a feeling
it will be him helping me.
I suggested changing out all of them including the drive shaft set,
since they haven't been looked at in the 10 years he has owned the car.
:confuse:
Any suggestions from you "Six-Pac" guys and gals will be appreciated.
FRank C (6TTR3A)
mrv8q
Hate to say I chickened out, and had a local driveline shop put in the U joints. I supplied the joints, and they put them in for a very reasonable price. I found taking them out relatively easy, you might want to have replacement rubber covers standing by. Good time to check the 6 studs as well.
Not sure if it's possible to pull the driveshaft without dropping the diff. I'll wait for someone with more experience to chime in on that one.... Have fun!
sail
The drive shaft will come out w/o pulling the diff. I have done those plus the rear drive train, NBD except for the part of laying on your back under a car. I hate that.
sail
Hubs come off easy but, big but, they can't be rebuilt easily and when they go back on torque is, I think from memory, 16 lbs, not much easy to strip. Most put in Heilcoils or such. Weak point on 4A and 6. I did Heilcoils and reluctantly spent the $ for Goodparts hubs. Really the only thing way out of budget but didn't want to have the wheels fall off.
poolboy
How hard is it to pull the hubs?
Scott in CA
Removing the hubs from the trailing arms in the condition that you see in the picture I posted involves removing the brake drum, 6 nuts and a gaiter strap. The procedure is covered in the manuals.
TR3driver
Great Pumpkin - R.I.P
My suggestion : If it ain't broke, don't fix it !
No reason a U-joint can't last forever, as long as they are kept lubed.
RJS
Hi,
Of my 6 u-joints, some have grease zerks and some do not. Also, for the two u-joints on the outer axle shaft, there is not enough clearance to get the grease gun in there so I can't grease them. Any tips or advice on this?
Also, are all u-joints made alike? If not, what brand is recommended and size do they take? I've see Richard at GoodParts recommends Neapco u-joints.
GoodParts offers an upgraded axle shaft/hub kit which replaces the u-joints and sliding splines with CV joints. It's a beautiful set up which solves three problems:
-no clunk from worn u-joints
-no "twitch" from frozen sliding splines
-HD hub which upgrades (what some people say are) very weak ("dangerous") stock hubs.
The only downside is the expense!
poolboy
As far as greasing the outer U-joints, you might do it as part of your routine greasing of the sliding splines.
RJS
Ah, good idea. I always took the sliding spline apart from the differential side. I'd unbolt it from the diff and slide the female piece off. Pulling the hub may be slightly more work but, at least you're not on your back under the car.
RJS
Does any one know if I were to disconect the hub from the trailing arm and the axle shaft connection from the differential, can you slide the entire axle shaft (w/ both u-joints) out as a single unit through the trailing arm hole?
HerronScott
Bob,
You should as that's how I used to remove them.
If you have installed a TR6 half-shaft with the plastic(?) shield for the inner-most u-joint (or updated your TR4A half-shafts with them), I don't know if that makes this more difficult or not.
Scott
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
R TR2/3/3A Replacing rear springs Triumph 51
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
Jim_Gruber Replacing Spridget Coolant Spridgets 21
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
tomshobby replacing water pump Spridgets 1
D TR2/3/3A Patching, versus replacing floors? Triumph 15
T Replacing the crank pulley/damper Austin Healey 4
M TR4/4A Replacing the hood/bonnet onto the body Triumph 11
T TR4/4A Replacing Drive Train Seals Triumph 5
