replacing fulcrum pin
WALTER
Moss sent me two cork washers with the fulcrum pin repair kit. They seem awful large to go between the swivel pin and the A arm. The ID's are so much larger than the fulcrum pin.
Thanks,
Walter
They should be two different inner diameters Since the fulcrum pin is bigger on one side that the other. They do swell a bit too.
In any case, that's where they go.
The ID of the corks is not meant to match the pin, but rather the OD of the threaded bushing in the arm. The corks do not turn.
Peter
Have a good time putting those corks in and lining everything up at the same time. An extra hand is helpful.
Mark
Gesh, I had no prob at all.
Odd but I'll do it.
Thanks a lot,
Walter
