TR2/3/3A Replace wiring harness in steering column
Dick this is the drive side: the light green wire with red strip from the trafficker/steering column goes to the green and red double wires. The darker green and brown single wire goes to the green and brown for the flasher unit. There are NO extra wires on the driver side.
steve
Steve---it works!!!!!!!!!!!!!!!! Blink Blink Blink!!! The right front parking light had a very loose ground connection. I soldered it a bit and it now works like a charm.
Thanks so much for all your help. Could not have done it with out you.
Now if the Brit Repair Shop can sort the Slave Cylinder, I might soon be driving Paddy?
Dick
