I checked both Green/White wires on the drivers side. I got reading at the front and rear directional lights for both. I connected them to a 4 way connector with the green/white wire coming out of the steering column. No blink? Another problem, as if I did not have enough. The left blinker works front and rear. When I turn on the parking lights, no blinking on the working side?? DickOn the drive side there would be 3 green and white wires 2 from the main harness and 1 from the sub- harness of the blinkers. Only one green and white on the passenger because it is the green and white wirer extension from driver side that came around. The blinkers need to get to the passenger side and that is why there are 2 green and white on the driver side. Look in the trunk and see what color you have for each side that should give an understanding how the front and back wires work together for the lights in one harness
Hi Guest!
