steveg
9 times out of ten replacing the seal won't fix the leak as the problem is not the seal but the shaft it fits around I even tried putting two seals in and it still leaked . The shaft could be scored or marked in some way . Save yourself a whole lot of time effort frustration cursing swearing bloodied knuckles and and don't forget money and just put the corn head grease in and be done with it ......permanently
On mine, the bushing was worn more than the shaft. I replaced the bushing and honed it to fit using a brake hone. Then two seals and first STP (found out it has no lube properties) then Penrite. So far, no leaks for about 8 years.
PS -- the only reason I used Penrite instead of Corn Head was I had already bought it before finding out about the Corn Head grease.
