1960 Bugeye, left hand drive (USA) needs rigid hydraulic lines for brakes/clutch replaced with flexible lines. One 10' line from Master cylinder to clutch slave cylinder and the other 10' from Master cylinder to 'junction' which delivers fluid to the wheels. Appears I need 2 each 10' long(?). Need a source for these lines and have found new RIGID ones from an autosupply house here in US (Advanced Auto Supply). BMC obviously installed originals before installing engine. Getting rigids bent 'just right' with engine installed is practically impossible. Flexible lines would cut the labor down 90%. Any leads? I know the flair, thread, and connector is a bit of an 'exotic' British design, but in looking for flexis, don't know the name of the required nomenclature. Been too long since I sourced the rigids. Any tips appreciated in advance .... even if just the connector type.
