M
Member 10617
Just came back from a 95-mile ride and found that my front left tire has a slow leak. I took the wheel off and submerged the tire in water and discovered that the leak is coming from around the tube stem.
I need to replace the tube but have never done it on a wire wheel. I believe that the tire has to be taken off the old fashioned way, with tire irons, because (a) machines for the purpose can damage the wire wheel, and (b) no standard modern shop will touch wire wheels.
Can someone give me some advice here: (a) where to find proper tire irons, (b) how to use them properly, (c) any precautions to take while removing the tire to insert a new tube.
It's been 50 years, at least, since I changed the tube in a tire.... and that was a steel wheel on an American car!
As for the tube. I plan to inflate the new tube three times before inserting it, to get out any wrinkles, etc.; I plan to use a band to protect the bue from the spoke ends; and I plan to put some talk on the tubes as I finally inflate them in the tire.
