Aldwyn
Ok, picked the car up from the shop last night... found that the valve cover appears to be leaking oil near the battery compartment tray. There was a bead of oil in several areas around where the cover and the head meet. There seems to be oil around the engine in that area as well. Is this normal for the first few miles the car is driven after the valve cover is put back on, or is this sloppy work?
Also, where the heater valve goes into the head, I can see where quite a bit of antifreeze is leaking.
That I know is sloppy work.
Amazing...
Amazing...
