Removing Wiper Arms
Keoke
Careful persistence, corrosion sometimes makes them difficult to get off.
John Turney
There is a little tab on the bottom of the arm, but there can be corrosion as Keoke says. Maybe a little PB Blaster on the underside.
DerekJ
While on the subject of wipers, did any model Healey originally use the Lucas type that have a screw to tighten the arm in place? i am now using them on my car. Well actually I only have a drivers side wiper to reduce the drag on a not very good wiper motor.
Keoke
DerekJ
I have never seen or heard of a wiper like that on a Healey
andrewss
Having scratched the front shroud on at least 2 Healeys trying to get them off DO NOT force them off !!!!! They are on a spline and need gentle coersion using WD40 (or usa equivalent) left for 24 hrs. Mask the paintwork with tape and then use a rubber pad around the wiper rotor that protudes from the shroud. Cut a 'U shape in a piece on 4mm alu the same diameter as the rotor. Ease the alu between the rotor and rubber pad and GENTLY for the wiper blade off... A lot of work for a small job but you won't regret it.. Obviously grease them when you fit them on the spline again.. GOOD LUCK AND patience...
HealeyRick
HealeyRick
Thanks guys . Mission accomplished (sort of, look for a new post on lubricating the cable) I was pressing up on the small tab with the tip of a screwdriver all the while worrying I'd gouge the shroud, but the arm wasn't budging. I realized that while pushing on the tab, I was also pushing the arm at an angle to the shaft, which was preventing it from pulling straight off. I used a pair of water pump pliers to push up on the tab and allowed me to pull the wiper arm straight off.
DerekJ
Keoke.
That's what I thought. My current car came with them. They are typical Lucas models and use a screw which tightens into a small tapered collar. Quite a good system. No idea which type of British cars they were fitted to.
Bruce
Question--I am removing the wipers for paint. You said you were pushing up, and I want to clarify you were pushing parallel to the wiper shaft. If you were pushing perpendicular to the shaft, do you push toward or away from the shaft? Thanks.
red57
Hi Bruce, Yes just pull straight (parallel) off the shaft but you may need to wiggle side to side to loosen any corrosion bond that has developed in the fine splines.
I have a set like DerekJ describes and they are very easy to install and remove/reposition - unlike normal push-on ones, there is no straining involved once you loosen the clamping screw. Mine are TEX brand but I have no idea if they are OEM or aftermarket. They also have a very simple hook shaped spoon at the outer end for attaching the blade. Another advantage of the clamping system is the splines don't wear and allow the arm to slip. I heartily recommend them if you ever find some.
Bruce
Thanks. Unfortunately, I have the original style. I've sprayed them with penetrating lubricant and will let them sit. I had no luck initially. It looks like the tab has to be pried outward along the axis of the wiper arm to allow the wiper head to slide off the spindle. I'm trying to confirm the direction of force on the tab. I've tried a small screwdriver and an assortment of picks and awls so far.
T TR4/4A Removing wiper motor - inner cable Triumph 4
W Removing wiper arm on 74 XJ6? Jaguar 0
D removing wiper bezels Spridgets 6
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing Glass Windshield Triumph 4
