Trying to remove my wiper arms (originals) and they aren't cooperating. Am I missing something? Any tricks or hints?
Question--I am removing the wipers for paint. You said you were pushing up, and I want to clarify you were pushing parallel to the wiper shaft. If you were pushing perpendicular to the shaft, do you push toward or away from the shaft? Thanks.Thanks guys . Mission accomplished (sort of, look for a new post on lubricating the cable) I was pressing up on the small tab with the tip of a screwdriver all the while worrying I'd gouge the shroud, but the arm wasn't budging. I realized that while pushing on the tab, I was also pushing the arm at an angle to the shaft, which was preventing it from pulling straight off. I used a pair of water pump pliers to push up on the tab and allowed me to pull the wiper arm straight off.
Thanks. Unfortunately, I have the original style. I've sprayed them with penetrating lubricant and will let them sit. I had no luck initially. It looks like the tab has to be pried outward along the axis of the wiper arm to allow the wiper head to slide off the spindle. I'm trying to confirm the direction of force on the tab. I've tried a small screwdriver and an assortment of picks and awls so far.Hi Bruce, Yes just pull straight (parallel) off the shaft but you may need to wiggle side to side to loosen any corrosion bond that has developed in the fine splines.
I have a set like DerekJ describes and they are very easy to install and remove/reposition - unlike normal push-on ones, there is no straining involved once you loosen the clamping screw. Mine are TEX brand but I have no idea if they are OEM or aftermarket. They also have a very simple hook shaped spoon at the outer end for attaching the blade. Another advantage of the clamping system is the splines don't wear and allow the arm to slip. I heartily recommend them if you ever find some.
I know the feeling!Hi Bruce,
I'm sorry it's been so long ago I really don't remember how I did this.
