Removing windshield from Austin Healey 3000 BT7
Chartliebt7
I need to remove the windshield from my 1960 Austin Healey 3000 (BT7) in order to repair the material on my dashboard. I thought it required me to remove the 4 screws found inside the door pillers and 2 screws on the fender. Suggestions?
Thanks for your help.
Charlie
bighealeysource
Bronze
Hey Charlie,
I had my 1958 BN6 apart and seem to recall that the windshield posts were attached with the two bolts per side on the bottom of the post and of course the large chrome screw that attached the top of the foot to the shroud. There was also a smaller screw that threaded into the post from the inside so maybe that's the one you have missed. I do not recall any other screws. You should probably also have spacers between the vertical post where they attach to the body. I realize a BN6 was a two seater but believe from the doors forward would have been identical to a BT7. If there was something else I sure don't remember.
Regards,
Mike
C
Chartliebt7
Thanks Mike. I think you are right about the smaller screw that Have to access from the inside. I'll tackle that over the weekend. Thanks again.
Best,
Charlie
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
K TR2/3/3A Removing windshield stanchions? Triumph 8
KVH TR4/4A Removing Glass Windshield Triumph 4
M Removing scratches from windshield Triumph 25
R Removing 66 BJ8 Windshield frame Austin Healey 23
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing the Differential Triumph 7
