Chet Zerlin
Hi all!
Continuing on in my quest to strip my car as much as possible before taking it into the painter...
The rubber gasket that sits under the windshield posts will need to be replaced which means those posts have to be removed from the car (which will also help the quality of the paint job). It looks like the windshield frame which contains the glass is held onto those posts by the screws in each post and the post itself is held into the body by two bolts on the side inside the door frame and one screw in the top "leg" that goes out onto the wing/fender. If so I am thinking that by removing the screws in the post I can remove the windshield frame in one piece. And then removing the two bolts and the one screw should get the posts out.
Seems easy...way too easy considering my experiences so far with my Healey (!) ...so before I try this idea would anyone know if this is correct?
Thanks!
Chet
Thanks!
Chet
Hi Guest!
