mightymidget
I stole this from another message board,
Is there a percentage formula for the ATF&acetone
For all of you that are mechanically inclined.... .
Penetrating Oils Compared
Machinist's Workshop magazine actually tested penetrants for break
out torque on rusted nuts. Significant results! They arranged a subjective
test of all the popular penetrants with the control being the torque
required to remove the nut from a "scientifically rusted" environment.
Penetrating oil ..... Average load
None ............ ......... 516 pounds
WD-40 ............ ...... 238 pounds
PB Blaster ............ ..214 pounds
Liquid Wrench ...... 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix... 53 pounds
The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic
transmission fluid and acetone.
Note the "home brew" was better than any commercial product in this
one particular test. A local machinist group mixed up a batch and all now
use it with equally good results. Note also that "Liquid Wrench" is about as
good as "Kroil" for about 20% of the price.
Hi Guest!
:banana:
