Rebuilt clutch parts
stinky60
Hey fellas,I need some opinions on getting the disc and pressure plate rebuilt or should I get new. If getting new wheres the best place to go.Thanks stinky
Get a new set made by Borg & Beck, sold nearly every where. You should get a new throw out bearing and you'll need a dummy input shaft to align the clutch disk and center it over the input shaft bushing in the crankshaft.
stinky60 said:
Thanks, Tim I figured,I should get everything new. stinky
:savewave:
:iagree:___Keoke
Hey Stinky
While you are at it, replace the bush in the end of the crank shaft, I am told that you break it up to get it out, but I did not even have to try hard, it fell out. You may also be able to get it out with a slide hammer. Check also the hing pin on the clutch fork to see if there is any play, mine wobbled all over the place and that, along with a broken spring in the clutch housing, caused terrific offset wear on the clutch thrust bearing.
best of luck
:cheers:
