pkmh
Hi Forum,
I have done some extensive research in the rebuilding of my front Armstrong Lever Shocks for the 67 Healey which I want to do "if they need" (and replacement of the upper trunnion assembly, which is a must!). I wish to keep my vehicle original, BTW. *(I believe that is the correct brand type labeled for these shocks)
I am about ready to remove them. After I remove them and if I can manually lift the wishbone armature up and down easily (enough), or if there is gurgling sounds of oil and "hitch" movement involved, then I believe it's time for either a rebuild or replacement.
Assuming for the moment I need to have mine rebuilt, I have been a bit unsuccessful in finding sites that show how to rebuild the innards of these shocks. I know about oil removal, cleaning, and installing new oil. Fork 30W Oil is one brand that has been recommended for the Healey--any other thoughts? I don't know if replacing the rubber seals to the pistons would suffice or if there is more involved.
Has anyone here ever rebuilt theirs? Just curious. I found one site that I can send them out and have it done. Good enough if no other option avail. Some years ago here on the Forum, a few members kept making mention of a fellow who was in the biz of rebuilding these shocks. That was some years ago--no trail possible now, it seems.
I would like to learn more about rebuilding my existing shocks, if possible. Otherwise, any other options or leads that can be worth investigating?
Thanks for any additional knowledge provided.
Paul
Paul
Hi Guest!
