Tabcon
Okay, I've got my rear end completely disassembled and the housing sanded and primed. I've removed all the guts and even got the the front and rear pinion bearings completely out and the races all cleaned up. I managed to get the wheel hubs off, which was not an easy task with loose axles and I even managed to remove part of the wheel bearing, the cage part. What's left are the inner bearing sleeves that attach to the axles. You would think that they're welded on by looking them, but I know they are supposed to break loose.
Without any special factory tools, or fancy hydraulic presses, is it possible to get these things off the axles using commonly available stuff and a little elbow grease?
I've got a new 4.1:1 ring and pinion and I'm waiting on Tran-X Salisbury LSD unit. I'd like to have everything ready to go when the LSD arrives, so any help will be mucho appreciated.
