Rear shoe upgrade?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Anyone have a better than stock rear shoe for a '79 avalible? I can't seem to find anything. I have some green stuff pads comming and new rotos and drums, now I need better shoes.
the usual suspect's shoes are just fine, most of the braking is the front and with your engine.....
What if he is wanting to do handbrake turns? :wink:
Maybe Carbo-Tech or Velvatouch metallic type material? Not sure if anyone is doing Velvatouches anymore. Carbo-Techs seem to be available from someone in Florida again. Check some of the enthusiast magazines for ads. Last metallic types I had done many years ago (Like the late 70's) came from the Richmond, VA area and didn't stay attached too well to the shoes.:)
The ultimate is a disk conversion, but be prepared for a lot of dollars to convert.
HTH,
Mike Miller
Forget about handbreak turns in a spridget. The think is so quick you don't have time to even think about it much less do it.
VB has some "performance" rear shoes. At $80 a set they better sure be. I have decided to make my car stop a bit better.
