Hello,
1966 Sprite Mk 3
Decided to do the easy part of my suspension rebuild. Nothing is ever easy on this thing. After fighting with it most of the day I now have the leaf springs out. All I want to do is replace the bushings; some of the bushing are very worn. I have broken off the bolts on the rear shackles. I found two shackles in my parts box; the problem is they are smaller. The distance between shackle pins is 1-½ inches. The broken shackle pin distance is 2-½ inches.
Could someone please measure the distance between the shackle pins? I would love to put this thing back together tomorrow. If I need to order parts it will be a week or so before I can finish the job.
Thanks Phil
1966 Sprite Mk 3
Thanks Phil
Hi Guest!
same here in the other direction
