TR2/3/3A Rear seat
Arrow
I am now building my rear seat bottom that sits on the shelf (later model post 60k) and have seen several photos showing various thicknesses. Mine is gone as it got wet. I called Moss but they are working from home. I’d appreciate some rear seat photos and thickness measurement. The end of a very long restoration is finally drawing near.
Graham H
This may help.
Graham
A
Arrow
Thank you! Those dimensions are exactly what I needed. Do you perhaps know how thick (bottom of plywood to top of leather/vinyl is.
DavidApp
I cut my ply from a sheet of 3/4" and used the dimensions in the last drawing.
Got the foam and covering from Skinner in the UK. The foam appeared to be too thick but I found that by compressing it with clamps I could start to get the staples in the board. Tuned out great.
David
DavidApp
I am on vacation at the moment so I can't get a measurement for you.
A get together would be great. I am in Macon.
David
DavidApp
Sorry for the delay in posting the photos.
Back from Vacation now.
This is what I have on my rear seat. If I had not pulled as much material around to the underside the seat would have been thicker. I had a struggle getting the foam pad compressed enough to staple the edges.
David
D Rear Seat Side Panels, BT7 Austin Healey 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
J TR2/3/3A TR3 Rear seat Triumph 11
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
S BJ8 Rear Seat Side Panels Austin Healey 3
Jayplum TR2/3/3A Support for back rest rear seat Triumph 4
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
T Anchoring the Rear Seat Pans Austin Healey 15
S Wanted Rear Seat Slide Bolts, BJ8 Austin Healey Classifieds 0
S TR4/4A Rear jump seat Triumph 6
Popeye TR4/4A Attaching rear of seat to seat slides...? Triumph 3
M TR4/4A TR4 with Surrey Top......Rear seat upholstery assistance please. Triumph 2
P TR2/3/3A Missing rear seat back rest/bulkhead. Triumph 7
J TR2/3/3A 1957 rear seat carpet pictures Triumph 7
M TR4/4A Rear seat upholstery assistance please. Triumph 2
rjc157 BJ7 Rear seat Back Austin Healey 5
T TR2/3/3A TR-3 Rear Seat Millboard Triumph 9
B Rear seat backrest pictures Austin Healey 6
S rear fold down seat Austin Healey 4
L Rear seat belts Austin Healey 26
M Rear Seat Austin Healey 2
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
Got_All_4 TR2/3/3A Triumph tr3a occasional rear seat Triumph 14
H holes rear seat area Austin Healey 7
B Installation of New Rear Seat Surround Panel for a BJ7 Austin Healey 8
maxwedge5281 rear seat pans for bj7 Austin Healey 2
J TR2/3/3A How to attach rear seat tabs to anchor the seat back??? Triumph 2
O Rear Seat back Removal British Motor Corp 0
C BJ8 Rear Seat Back Carpeting? Austin Healey 3
C Rear seat panel BJ7 & ignition coil help Austin Healey 14
B Rear Seat Pan Seal Austin Healey 3
Frankenhealey Optional rear seat for a Frogeye? Spridgets 10
G Removal of rear seat pans Austin Healey 16
H rear seat pans for 4 seater Austin Healey 3
mountainman TR2/3/3A TR3 Rear Seat Triumph 3
GregW Rear Seat Dimensions Austin Healey 7
Gordon_Dedrick TR 3 occasional rear seat Triumph 4
L BJ 8 Rear seat belts Austin Healey 2
ekamm TR2/3/3A Rear seat tr3a Triumph 4
longbridgehealey rear seat pans for 100-6 Austin Healey 26
HealeyPilot Rear seat belt for 1960 BT-7 Austin Healey 9
chicken what size should the holes be to take my rear seat Austin Healey 9
MGTF1250Dave TR2/3/3A TR3 Optional Rear Seat Triumph 22
CraigLandrum TR2/3/3A TR3A Rear Seat Questions Triumph 13
chicken BJ7 rear seat pans Austin Healey 0
