Rear differential drain plug leak
Lin
I tried some thread sealant but a small leak persists from the drain plug. To those who have solved this annoyance, what did you use on the threads? Silicone sealant?
Thanks!
Lin
Jack T
Thanks!
Lin
Might be the type of sealant you used. Make sure it's suitable for use with oils.
Keoke
Thanks!
Lin
Try plumbers Blue tape Lin.
Thanks!
Lin
I've always liked to experiment with sealants and adhesives (much to my father's annoyment), but don't like using teflon tape where a piece could break off and 'gum up the works' (yes, I know it wouldn't do much in a diff). Permatex Thread Sealant (with teflon), has always worked for me; if it doesn't for you I'd look closely for a crack or defect in the plug or the threads of the diff case.
As an aside, the following shows some, er, 'interesting' things going on in a diff:
https://www.youtube.com/watch?v=9-yG3D3JBRs
Deleted member 21878
i use the pink teflon tape. worked fine and is for oil.
Loctite 518. It's what I use on bolts that are in open-end threaded holes into BMW differentials (below oil level).
It works as a bit of a thread-locker too, so additional effort will be required the next time you go to drain the fluid.
Good stuff to keep around, as it will substitute for a gasket altogether. https://www.walmart.com/ip/Gasket-S...MIqvzMotG-3gIVCJyzCh1pVgNbEAQYAyABEgJPsPD_BwE
pkmh
I just replaced my differential gear oil last weekend. I used the black sealant from Permatex, also referred to as, "Make a Gasket" Sealant. Claims to be good when using with oil. Used it in conjunction with my cork type gasket to my valve cover, too. No leaks.
Michael Oritt
Lin--
Consider drilling and safety wiring all your drain plugs--diff, engine, transmission. It is mandatory on race cars for a good reason and there will be one less thing to obsess about!
OK, I can't for the life of me see how you can safety wire the diff and gearbox plugs; they're recessed and if you drill you'd likely go through threads. I've never heard of one backing out, as I believe they're pipe threads and you can torque them down pretty tight.
Michael Oritt
Bob--
There is enough thickness on the face of a plug to through-drill a small hole in at an angle into which you can insert the wire. Some plugs stand a bit proud of the surface of the housing and they are easiest. For those that go flush when tightened it may be necessary to drill two angled holes so they meet and allow the wire to be passed through. Finding a place to anchor the wire is easy and on diffs I use an oval or oversized washer near the plug and drill a hole through that.
Needless to say, drilling out the plugs should be done with them off the car....
Probably not necessary on a street car; at least, I don't lose any sleep over them falling out. Presume you use stainless wire? What thickness of wire do the tracks specify?
Michael Oritt
Bob--
It's probably not necessary on a track car either but it is what it is. I have never seen a spec for either size or type of wire--just that all drain plugs must be "wired"--nor have I ever seen a tech inspector get under a car to check, though engine sup drains are usually easy to see from above. Personally I enjoy the exercise.
I built this engine for a guy that races, and asked him to send me the engine specs out of the rule book__I didn't want to inadvertently get him in trouble...
You know, just to present a visual aid to Michael's suggestion!
T Rear/Differential "Clunk" Austin Healey 2
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
J TR6 Differential / Rear Axle Triumph 1
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
P MGB Noisy Rear Axle / Differential MG 1
D TR2/3/3A rear shelf differential dome Triumph 9
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
KVH General TR Rear Differential Seal Triumph 7
C TR2/3/3A Rear differential Triumph 29
A Rear Differential Concern??? Triumph 11
T Spitfire Spitfire differential rear bushings Triumph 5
KVH TR4/4A TR4A IRS Front and Rear Differential Bridge Pins Triumph 6
J Rear Axle/Differential Gear Oil Spridgets 13
zschicago Replace rear differential gasket? Austin Healey 12
R MGB MGB Tube Type rear differential MG 0
R use redline mt-90 in 1275 rear differential? Spridgets 3
N Differential and rear suspension Austin Healey 113
I rear axle to differential flange bolt grade? Triumph 8
N Rear Differential Rebuild Triumph 9
KVH Rear Differential Overflow Valve Triumph 3
Lin Rear Differential bearings Austin Healey 2
C TR2/3/3A Broken TR3 rear differential Triumph 9
G Rear Differential - Pinion Gear? Austin Healey 3
jerrybny Differential/Rear Axle Gaiter question Triumph 6
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
