TR2/3/3A Re-torque my rebuilt TR-3 head
Koopster
Member
My rebuilt Tr-3 has now 500 miles on it.
I need to re-torque the cylinder head bolts on this engine. I do not know the correct way to do this. Do I just set the torque wench to 105 lbs. and see if the bolts tighten more or do I need to first loosen the head bolts back down to like 75 lbs. then bring it up to the recommended torque level?
This should be a easy one for you form member.
Thanks, John
HerronScott
Koopster,
I don't know about the official or correct way to do it, but I just rechecked the torque (ie did not loosen them).
Scott
TR3driver
Great Pumpkin - R.I.P
Torque readings should be taken with the fastener moving; meaning the 'official' method is to loosen each bolt and then retighten it.
HerronScott
See told you mine wasn't the official *or* correct way. :smile:
Scott
vivdownunder
Re-torque them down dry - wipe any oil off the head nuts inside the valve cover before loosening them.
Potential trouble if the manifold side head nuts get re-torqued dry and the inside nuts are re-torqued with oily washers.
Then check the tappet clearances.
Viv.
hondo402000
so would you loosen all first and retorque all or loosen one retorque, and go to next bolt in the official sequence
TR3driver
PeterK said:
I'd do them one at a time following the torque sequence.
:iagree:
K
Koopster
Member
Thanks for all your input. I can see that there is really a lot to consider when re-torque the cylinder head bolt. It looks like I need to first back off all the nuts in the reverse order of tighten, then clean the the nuts and washers of the bolt exposed to the lub oil then re-tighten them in sequence.
Thank again for all the help.
If anyone thinks of some thing else to consider, please chime in.
John
TR3driver
Personally, John, I think it's much better to do them one at a time. That way, there is no chance of breaking the seal between gasket and head, which could potentially allow coolant to leak during the process.
IMO, just wiping off the oil won't make enough difference to matter. To really get a "dry" condition, you'd have to degrease both surfaces ... too much work. I have always just torqued them "as is" and never had a problem without a more obvious explanation (like liner protrusion).
I'm not saying the oil does not make a difference. But the difference is that the oily fasteners wind up clamping the head harder for the same applied torque. This is not a problem unless the studs start to stretch, and the factory studs appear to be plenty strong enough to carry a little extra torque.
Mkutz
A follow up question -- Is removal of the rockershaft accomplished merely by loosening the nuts on the pedestals one turn at a time as to avoid undue tension on the shaft caused by open valve springs? Any added tidbits regarding the removal and reinstallation of the shaft? Anyone know the torque setting for the pedestal nuts? I suppose a valve adjustment job is in my future. Thanks all!
TR3driver
That will work. Torque is specified as 24-26 ft-lb; and of course you set the valves afterwards (although they should be close).
The book shows split lockwashers under those nuts, but I prefer to use hardened flat washers. The lockwashers really tear up the pedestals, and I've never had a problem with the nuts backing off.
J First oil change after rebuilt and head torque Spridgets 6
Carlbanan56 MGB Rear axel torque? MG 4
C Steering Arm Castle Nut Torque Austin Healey 5
P TR2/3/3A British High Torque starter Triumph 6
B Head Re-Torque Austin Healey 8
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
W TR2/3/3A Differential cover torque Triumph 4
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
M High-Torque Starter Austin Healey 10
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
B High-Torque Starter Rattling Noise Austin Healey 3
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
Lin Oil sump torque value? Spridgets 3
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
D Torque Sticks Restoration & Tools 6
J TR2/3/3A Head Torque - Wet or Dry Triumph 6
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
R Our J-H plan - torque specs needed! Other British Cars 2
S Locknut - rear wire wheel - torque spec? Austin Healey 15
S TR2/3/3A Torque specification on large pitman arm nut Triumph 1
Michael Oritt Torque values needed for 100 Austin Healey 5
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
G Torque for Front Pinion Nut Austin Healey 3
D torque values Austin Healey 2
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
Jim_Stevens TR2/3/3A Axle to leaf spring torque Triumph 2
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
G TR4/4A ARP Bolt Torque Specs Triumph 10
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
tr3guy TR2/3/3A TR3 Fan Bolt Torque Triumph 3
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
M_Pied_Lourd TR2/3/3A Hi Torque Starter Repair Triumph 14
S Torque setting for U-Bolt nuts Austin Healey 12
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
S Torque Range? Austin Healey 13
KVH General TR That Front Fan Dog Bolt Again--Torque It Triumph 7
K TR4/4A Gearbox front cover[Moss 848-000] torque spec? Triumph 1
Griz Manifold nut torque Austin Healey 11
B re-torque heads? Austin Healey 5
J Need dimensions for BJ8 PII radius [torque] box carpet flaps. Austin Healey 1
