Re-Chroming BJ8 Windshield Surround
Chris_Masucci
Hi Folks,
So what is the consensus on plating the windshield surround? Is it absolutely necessary to drill out all the rivets and plate separately, then hope to get new rivets in without damaging the fresh plating? If so, I have found through searching that BCS has the rivets, but I would have no idea where to find a tool to do it, besides a hammer.
I would much prefer to just take it as best it can be done without popping all the rivets out, and some older posts linked to some pictures of the side pieces done that way...however those old links are broken. Can someone point me to some pictures of an after shot of plating done with all the rivets left in place?
Thanks a bunch!
saltiga
hello chris, I dont know if this is the answer you are looking for but will pass on what i know. I completely stripped my wind shield down as the chrome work was rather tatty for being left out in the open for many years, all the steel parts were badely rusted, i made all new replica parts out of 316 stainless steel, machined all the rivets out of stainless rod, domeing them in the process, i rivetted them all back with just a ball pane hammer, being very careful and it turned out as good as the originals. the corner angle pieces were also made of srainless with stainless allen key hs/head screws. I approached a Healey restoration expert for advice to have the other pieces rechromed, his advice was, be very selective of who to use as they can buff the piece to oblivion, he next said that others he knows of after rechroming cannot get the rubber seal back in as the rechromeing fills the grove up too much. Hope this helps saltiga
Patrick67BJ8
Hi Folks,
Thanks a bunch!
I just picked my windshield from the glass shop after having new glass put it. I had it chromed back around 1980ish. Do you still need photos?
C
Chris_Masucci
Thanks for the response folks. I guess I'm going to wing it and try leaving the rivets in. My plater seems to think it will turn out ok, but they do have some concerns with ensuring all of the previous bath is rinsed from between the parts. They assume it will just take longer to rinse between stages. I'll take some pictures after and you can let me know if it passes for you or not.
Patrick67BJ8
Here's some pics of mine that was done in the early '80's and it's still holding up.
C
Chris_Masucci
So, I finally got my estimate back from the local platers. For the windshield surround, grill pieces, cockpit surround, door window hardware, door handles, door trim headlight trim they want $4K. Sounds pretty ridiculous to me, but was wondering what you folks think is a fair price. $825 for the cockpit surround alone seems out of control.
Any suggestions in the midwest for a reasonable plater?
Patrick67BJ8
Ridiculous prices!! I just paid $350 for my cockpit suuroud, door trim chrome(2 small pcs and two long pcs for window trimming).
C
Chris_Masucci
May I ask who you used? Seems like I need to be open minded about shipping my parts out instead of staying local, although I haven't exhausted my local options yet...still two or three more places to check.
Patrick67BJ8
I used J&B Polished & Chrome, Ft Worth, Tx.(NFI) 817-723-1077. Very fast turn-around time(approx. 1 week). I also had my grille surround and eyebrow done too. I had the grille teeth polished which was a mistake. Second time it was done, the first was about 1980, and the buffing went throught a couple of teeth(not too noticeable but the teeth can't be polished on the edges/sides). They can do the knock-offs, etc. The"cockpit surround" is going to be expensive too ship. Whoever you use...be sure to take photos and keep a set and also send a set to the Shop doing the work. J&B has bumpers, etc., shipped to them from all over the US.
PAUL161 General MG Chroming Wire Wheels MG 9
J Chroming the Bugeye grille -$850?? Spridgets 15
angelfj1 Bumper repair/chroming service in Charlotte, NC Triumph 9
B Re-chroming vs. New Part Restoration & Tools 3
newmexTR3 Re-chroming valve cover badge Triumph 5
Tinkerman TR2/3/3A Cost for Chroming TR3 bumper Triumph 16
Randy Harris Re-chroming - looking for some guidance Austin Healey 8
C Re-chroming service Austin Healey 13
jlaird Some prices, chroming and anadozing Spridgets 1
R6MGS Chroming Wheels Other Cars 2
KLUTZ The cost of re-chroming is? MG 1
R Re-chroming or New parts? Spridgets 2
MGFever Re-chroming MG 2
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
