I have just received my long block back from the builder with all new bearings, pistons/rings, front & rear seals. To complete the block I have the Front Engine Plate, Front Cam Bearing, Cam Gear,Timing Chain, Oil Pump, Distributor, Flywheel, Oil Pan and Timing Cover to install. I do have the TR Mtc Manual, and alittle past TR engine experience.
Any helpful hints , other then installing the Front Engine Plate, Oil Pan and Timing Cover with be greatly appreciated. I do need some help in installing the Cam Gear and Timing Chain correctly. The Oil Pump install appears straight forward. The valves have been adjusted by the builder and assume there is not something else i need to do with the valve timing.
You guys have been great in the past in trouble shooting my posts.
Dick Vinal
Dick Vinal
