MGB RB MGB rear lisence plate holder.....
R6MGS
I am trying to foresee some future problems before I get stuck when I am in a rush....I noticed the rear lisence palte holder on one of my 78's is getting a little rusty and could use a painting.....I know theres two screws in the middle of it holding it on....I am worried about getting the wiring to the lisence plate lights disconnected though....where should I disconnect it if I want to remove the entire metal holder?
If it's like the 75 there will be 4 bullet connectors on the harness running down the back of the trunk. 2 on each side of the trunk latch bout half way to the reverse lights. Disconnect them and remove the 2 bolts and it should come right out.
Stewart, is correct - its a pretty simple procedure. Jut pop he to locate the wires trunk and everything is right there.
I actually re did last year. First cleaned & scuffed it up with some fine sandpaper. Then I painted it with Rust-Oleum flat black paint.
Then reassemble it and feed the wires back into the truck and reconnect. That's it - Yer done!
[ QUOTE ]
... Jut pop he to locate the wires trunk and everything is right there... <snip>
[/ QUOTE ]
err... my decoder ring is actin ' wonky. WAZZAT?!
"Please repeat last transmission?"
Man, Keenanitis is spreading.
i git it. He types better than doc talks......
mark
**translation: pop th' boot 'n everythin's right there...
that help? /ubbthreads/images/graemlins/jester.gif
Doh! /ubbthreads/images/graemlins/eek.gif
Sorry, my brain is totally fried at the moment. What can I say I had a long day at work only to be confronted by my teenage son who asked for help with his homework?
I don't recall my homework being this difficult when I was in the tenth grade. But then that was more than thirty years ago.
Rob's correct in his translation: If ya pop open the boot and everything is right under yer nose.
Thanks....glad to hear it's easy
.....and the list of summer projects continues to grow...
Bret, Sarah's 26 and I couldn't help her with her homework after about 8th grade! It's awful, isn't it!? You know, if he does need some extra help in a particular subject, check into some peer tutoring through the school.
