My car is completely dismantled undergoing a restoration from the gound up so I don't know about having to pull the rear end to replace those bushings, but I used a press and an old bushing to remove the 4 old bushings and to install the new ones. I did take some fine grit sandpaper to cleanup the surface for the bushings to slide in easier.dancrim said:Has anyone replaced the bushings in the radius arms. Any tricks to removing the old ones and pressing the new ones in? Also,do you have to pull the rear end back to get the arms out?
If you're talking about the rear leaf spring bushings they can be a real problem. Usually you have to cut the bolts off and remove them with the springs. There's a metal sleeve inside them that rusts to the bolts.dancrim said:Has anyone replaced the bushings in the radius arms. Any tricks to removing the old ones and pressing the new ones in? Also,do you have to pull the rear end back to get the arms out?
