Radius arm bushings
dancrim
Has anyone replaced the bushings in the radius arms. Any tricks to removing the old ones and pressing the new ones in? Also,do you have to pull the rear end back to get the arms out?
Patrick67BJ8
My car is completely dismantled undergoing a restoration from the gound up so I don't know about having to pull the rear end to replace those bushings, but I used a press and an old bushing to remove the 4 old bushings and to install the new ones. I did take some fine grit sandpaper to cleanup the surface for the bushings to slide in easier.
Go slow and get an extra set of hands to help and you shouldn't have too much problem installing the bushings. If you have a machine shop close by, you could have them do it.
The hardest part of removing the old bushings is when they are frozen in place over the years. I did remove a bushing back in '74 but I was also changing a broken spring too. I greased the bushing bolts on all of them when I did this and it only took me a few minutes to remove them when I dismantled my car. The same goes for the front bushings. A little bit of grease or anti-sieze works wonders down the road.
Patrick
Johnny
If you're talking about the rear leaf spring bushings they can be a real problem. Usually you have to cut the bolts off and remove them with the springs. There's a metal sleeve inside them that rusts to the bolts.
Cutlass
This is a job that I left to the guys with the hydraulic press and the appropriate accessories. Small investment, perfect result. You can do it in a two stage process, getting the old busings out first, bead blast the radius arms, then prime and paint. Take the shiny arms back to get the new bushings pressed in.
Genos2
Johnny,he's talking about radius rod bushes, on the Phase 2, they mount above the leaf spring & connect to a pocket in the inner apron.Old bushings can either be cut or pressed out. Not that difficult,I agree, I would paint or powder coat the arm before installing new bushes. Genos2
dancrim
Guess I'll make some pressing dies on the lathe and beg or borrow a press.
I'm hoping this will cure my "jerk to the right" problem when hard shifting
No pun intended.
Genos2
Harbor freight has inexpensive bushing press arbor kits, I got one & it works well. Also old bearing races &seal installers work well,no point in building arbors for a one time use,unless your bored. Merry Christmas to all-Genos2
histerical radius arm bushings Spridgets 2
T Radius arm clean-up and bushings Spridgets 7
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
B Radius Arm 67 3000 Austin Healey 12
boeingpilot GT6 Looking for a GT6 Radius Arm Bracket Triumph 5
BugeyeNJ58 Radius arm came out...how to put new one in? Spridgets 6
Trevor Jessie Looking for a radius arm bracket Spridgets 8
Ohiobugeye Whats the key to removing the rear radius arm bush Spridgets 6
C Rear radius arm attachment Austin Healey 9
B Rear radius arm bushing removal Jaguar 12
71TR6 TR2/3/3A Moving a radius on sheet metal patch Triumph 12
J Need dimensions for BJ8 PII radius [torque] box carpet flaps. Austin Healey 1
bighealeysource Increasing door opening radius on 100-4's Austin Healey 0
bugedd Rear radius arms Spridgets 4
D Removing radius arms. Austin Healey 7
T Reinstalling radius arms etc... Spridgets 4
M Radius Links Spridgets 5
T Radius arms - now what? Spridgets 6
AUSMHLY Turning radius Austin Healey 5
B E-Type rear radius arms Jaguar 8
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
C Steering Arm Castle Nut Torque Austin Healey 5
WHT Rocker Arm Shaft Replacement Austin Healey 21
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
W Steering Arm Colors Spridgets 1
R TR6 Lower A-arm trunnion bushings Triumph 18
D MGB Rear Suspension Damper Link Arm MG 2
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
Rob Dodge Trafficator arm issues. Jaguar 2
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
M TR2/3/3A Cracked Welds on Steering Idler Arm Triumph 5
F Refilling and servicing Armstrong Lever Arm rear shocks Austin Healey 4
Rut TR4/4A A arm orientation Triumph 2
T TR5/TR250 Wiper wheel box knurled end not tight on arm Triumph 9
AH67 Wanted Wanted steering Idler Box & Arm Austin Healey Classifieds 3
F TR2/3/3A Beware eBay wiper blade and arm sales Triumph 6
S TR2/3/3A Torque specification on large pitman arm nut Triumph 1
T TR6 ajustable training arm brackets--- 1974 TR6 Triumph 14
D rocker arm assembly Austin Healey 14
G TR4/4A Wiper Arm Question Triumph 13
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
KVH General TR Pressing in the Lower Control Arm Bushing Triumph 6
Tim Tucker TR6 Trailing Arm NYLATRON bushing-washer gap questions Triumph 4
J BJ8 arm rest with compartment Austin Healey 1
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
