radio antenna location
maxwedge5281
there are a few threads regarding this subject but nothing totally definitive. after a search of bj7 model picures the antenna if present was located in the passenger front fender or in a similar close proximity in the shroud. well mine is in the shroud above the package shelf on the passenger side. the shelf had been removed so that the retractable portion of the antenna would...retract. i dont care for a radio nor the remaining antenna hole. and, the body shop tells me that they will have to repaint the entire shoud if they fill the hole.....lots of dollars! so, i will most likely replace with an antenna in the fully down position. any ideas or suggestions of other ways to attack this. View attachment 33188
Legal Bill
1. Paint a suitable sized rubber or plastic grommet the correct color and stick it in the hole.
2. Mount a period looking waterproof clock in the hole and tell people your car is an ex-ralley car and that was set up for the navigator.
3. Mount a deer whistle in the hole. https://www.jpcycles.com/product/91...g&matchtype=&gclid=CM7Cip7_ur4CFVQFMgodQggAYw
4. Mount a spot light in the hole and tell people you have an ex-police Healey.
5. Find a suitable grill badge and mount it in the hole.
6. Create a rallye registration badge and mount it in the hole. Tell people it was something that they put on all the Mille Miglia rallye cars...
7. Mount a small scoop over the hole. Duct the hole down to your feet. Enjoy cooling air on your toes in the summer time.
8. Buy a Go-Pro camera and use the hole for the camera mount. Video all your travels and post the videos here. Wire it to an alarm system and video tape the theifs.
9. Bolt a rear view mirror into the hole and tell people it is a courtesy mirror for your passenger.
10. Mount a Healey emblem to something big enough to cover the hole and mount it over the hole.
Let us know which one you choose.
Keoke
the body shop tells me that they will have to repaint the entire shoud if they fill the hole..:iagree:,
i will most likely replace with an antenna in the fully down position..
This saves you $$ and simplifies the addition of a car cover [sans leaks] at a later date
maxwedge5281
maxwedge5281
if my gps receiver for the speedometer wasnt square i would sit it over the hole...too bad it isnt round! too bad they dont make a fake retractable antenna that does not retract...just the base. i will most likely attempt to cut off most of an antenna and just mount the base... anybody know of a fake base being available! and thanks for all the suggestions....cheers
HealeyRick
Hood tach:
Dual Appleton Spots:
Bugeye Jack Plug:
Frenched antenna:
NOS purge:
steveg
Another possibility - look at it like a craft project.
Epoxy a piece of aluminum behind the hole. Cut a matching hole in a piece of wide teflon tape and use it as a mask. Fill the hole with surface putty. Contour carefully. If it needs sanding and the teflon tape* mask won't work, make another out of duct tape and carefully block sand to same height as surrounding body work.
I beg to differ about the paint - a good painter should be able to match the paint and paint a small spot with a feather edge.
I might be tempted to spray over the area through a circular mask held above the bodywork - to give a feather edge - then color sand with very fine wet/dry paper.
*google Dyna Glide for the teflon tape.
HealeyRick
Steve,
Max's car seems to have some metallic in it, that might make a blend difficult particularly in such a noticeable place. My car came with antenna hole in the traditional spot on the right front fender. I used the same "hidden" antenna as GLemon linked so I wouldn't have trouble putting a car cover over it. I think it's the easiest, cheapest and least likely to look funny of the options out there, even if Max keeps it fully retracted all the time (although I would love to see someone's face at a stoplight if you purged your nitrous from that hole).
I might also try the plug that Steve pictured from the Home Improvement store and painting it to match the body, but I still don't think it would look as good as the antenna.
maxwedge5281
maxwedge5281
thanks guys. it is still hard to imagine someone drilling unnecessay holes into the shroud area to mount an antenna! think that i will purchase a chrome retractable antenna and modify the antenna below the mounting point such that it does not interfere with the package shelf...if it can be modified. i ordered the chrome retractable off ebay...10 buckx shipped. cheap experimentation for a possible fix!
Keoke
Keith_M
I was able to plug mine with a rubber plug. The top of the plug is slightly domed and textured; it doesn't look too bad, and I can always put an antenna in later if I decide I want one.
S Radio Antenna Spridgets 5
R radio antenna Spridgets 11
S TR2/3/3A tr3 radio antenna hole Triumph 15
bcbennett Radio antenna lead Triumph 3
angelfj1 TR-3A Radio Antenna Options Restoration & Tools 4
2wrench Dropped radio antenna into fender. Triumph 21
G Fully retractable radio antenna Triumph 5
RSMTR8 Wedge TR8 Radio and Power Antenna Triumph 4
jjbunn Radio Antenna MG 12
G radio antenna replacement Triumph 7
zoohow radio and console mount Restoration & Tools 1
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
J TR2/3/3A TRIUMPH Radio? Triumph 13
D Removing Old Radio Austin Healey 4
T TR2/3/3A Question on old radio from my TR3 Triumph 9
Got_All_4 TR5/TR250 Pros and Cons to Wiring The Radio Direct Triumph 6
E Alpine radio for a US Model Db7 Volante Other British Classifieds 0
Hangtown Healey Barbie Clock-Radio Austin Healey 9
M General MG OEM Radio wiring help MG 4
pkmh Radio Knob Design For A 67 BJ8 Austin Healey 16
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
T how to have music/radio when driving Spridgets 33
7 Strange A/C - radio problem Other Cars 7
Jim McCauley TR6 TR6 Radio recommendation Triumph 4
M Fitting a modern radio Austin Healey 9
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
1 MGB '66 MGB radio measurements MG 3
6 Spridget Radio/Speaker Case Spridgets 4
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
Tim Tucker TR4/4A BENDIX Radio Model: 5SMTR manual? Triumph 2
T Wanted Wanted: BE Sprite Original Motorola Radio Spridgets Classified 8
F TR2/3/3A radio mounting plate Triumph 4
H Vintage Radio Austin Healey 9
Zitch TR4/4A Original Radio knobs Triumph 12
M S1 e type radio console Jaguar 2
wangdango BJ8 radio delete plate? Austin Healey 2
Got_All_4 TR2/3/3A TR3 radio console Triumph 30
Marvin Gruber Becker Mexico radio Austin Healey 7
kennypinkerton MGB Radio console removal question MG 4
D Radio! Other Cars 0
Zitch General TR WTB - Triumph AM radio. Triumph 11
roysimpsonjr TR4/4A Will an 8 inch wide radio fit? Triumph 3
Scotsman General TR Radio Triumph 4
M TR2/3/3A Phone charger & Radio can I put these in my car??? Triumph 7
K TR4/4A Stock Triumph Radio Troubleshooting? Triumph 4
G original radio 1961 e series jaguar Jaguar 3
TulsaFred Bugeye radio in-dash Spridgets 10
B orginal BMC radio Austin Healey 9
Mink TR4/4A Radio plate/dash support orientation Triumph 6
