radiator spigot fix
why
After 32 years of ownership '65 3000, '67EType and at least the last ten of trying to stop leak from radiator spigot including lapping the valve seat, and buying a new one that also leaked, a small cork bought at Ace hardware jammed into opening got it down to 2 drops an overnight. So finally decided to launch all-out war with plans to seal with solder, expoxy weld stuff etc, ended up with a stainless steel, fine thread, 1/2" dia, 1/2 inch long bolt from Ace hardware (small Ace store did not have but big store 4 mi up PCH did [tried six others home depot, PEP Boys etc.no luck]), also a plumbing dept washer, whitish plastic-like (used before and works fine). NO DROPS either car, no newspaper on garage floor at front, Jay
Nice fix! Except,...Now how will you know when the radiator is empty? :thirsty:
Humor, you know the old joke about how you can tell when your British car has run out of oil? Answer: When it has stopped leaking. Just having some fun. I am fond of the original radiator petcock's look. The stylish heater valve on the engine is my favorite.
I get it - we need it to leak so we know when it's empty. :glee:
They tried Lucas warning lights on the dash, but those burned out before the radiator emptied.
:lol:--------Keoke
Just a heads up, but the threads on the petcock/spigot are British Standard Pipe. To be specific, they are 1/4''-19 BSPP. Anyone looking for a drain plug, in stainless, they are available from British Tool and Fasteners. I have also purchased a similar item in brass from Ebay seller "bsanut".
​Both items were very good quality.
