TR4/4A Radiator Fan and plates spanning bolts
Giovanni59
Hi,
I am putting the after market fan back on the engine of my 1965 TR4 and there are two plates with holes that go over each set of bolts.
One is flat and the other is curved. I am not sure if the curved one should be hammered flat or is it curved for a purpose. It does not fit over both bolts in this curved state. The curved bend looks intentional. I do not even know what their purpose is.
Photos attached. I have owned the car for about 6 years and they have always been on there, however I never noticed them until now. The only thing that it reminds me of is in the electrical field where they need to be connected to complete a circuit. Thanks
G
Giovanni59
I just found out they are a sort of lock washer, they get bent up against the nut to keep them from coming loose. Those crazy Brits!
mrv8q
If it helps, Here’s what I had on my TR3 before replacing with the Mark Macy fan.
DavidApp
You will notice Kevin has the fan mounted backwards which you have to do on the TR3 to have clearance for the radiator. There is not very much clearance on the cross brace on the TR3 but it does fit.
Not sure about the TR4 setup.
Geo Hahn
I omitted the plates and used Blue Loctite on the bolts. Much simpler, especially if installing the fan w/o removing the radiator. Has held fine for many miles and years.
DavidApp
Not sure what was going on here but this is what I found on the fan hub on the TR3 I am getting running again for the owner, Note the lose bolt with the turned over tab. Two of the bolts were like that.
David
S Installing a Radiator Fan Austin Healey 9
RJS TR4/4A Radiator Fan Shround Triumph 3
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
J BJ8 Radiator Fan Austin Healey 12
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
FlyingCat Spitfire Electric Radiator Fan Triumph 10
FlyingCat Spitfire Radiator and fan Triumph 5
JFS TR2/3/3A Radiator fan temp probe Triumph 3
E TR4/4A TR4 Radiator position with Macy's garage Fan Triumph 6
Superwrench Radiator Fan Guard BJ 8 Austin Healey 4
J TR2/3/3A Radiator removal ?? electric fan vs original Triumph 7
rjc157 Electric radiator fan Austin Healey 11
DanLewis How far is your mechanical fan from the rear of your radiator? Spridgets 39
Patrick67BJ8 Kilmartin Radiator Fan Shroud Austin Healey 4
DanLewis Distance between mechanical fan and radiator core Spridgets 17
DanLewis Thermostatic fan switch that fits Bugeye radiator temperature sensor hole? Spridgets 19
johnrip Wedge tr7 radiator fan Triumph 1
RJS Radiator Fan Bolts - need quick help Triumph 4
RJS Balancing a radiator fan[?] Triumph 18
AUSMHLY Check out this radiator fan Austin Healey 6
eschneider custom electric radiator fan switch Lotus 3
Mark Jones Electric radiator fan replacement options Triumph 3
QuickSilver Radiator Cooling Fan MG 10
G Radiator - Fan - Coolant ? Triumph 4
QuickSilver Question On Radiator Cooling Fan MG 5
T TR2/3/3A Tr3 Radiator fan loose Triumph 33
pjsmetana Spitfire Spitfire Radiator Fan Triumph 3
K radiator fan shroud Triumph 21
Mark Jones Radiator fan motor - rebuild? Triumph 4
6 Moss Recall: Tropical Radiator Fan Austin Healey 46
kyreb1862 T-Series Radiator Cooling Fan Switch MG 6
P Radiator Fan Shroud [aka finger protector] Austin Healey 1
G Ron Davis aluminum radiator and Spal fan pics..... Triumph 9
T Wedge TR8 radiator fan recommendations Triumph 0
LastDeadLast Custom radiator and electric fan stuff. Triumph 3
S Radiator Fan Clearance Austin Healey 11
Michael Oritt Wizard Radiator Austin Healey 7
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
S Install drain cock in radiator. MG 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
