Quick tachometer wiring question on a '65
mgless
When I purchased the car I had no working instruments -- the correct tach, a RVI2401, came with the car but it wasn't hooked up. I've since found an induction loop from a "parts" tach, but I think I might still be missing a piece. I believe there is a metal piece that's supposed to go underneath the plastic induction block?
If so, does anyone have a picture of this piece?
This is from a 3" (later model) RVI tach but should give you the idea
BillM
I am fairly certain that the clip shown in the pictures is primarily for mechanical support. If you don't have that part I am sure you can make one from scratch using sheet steel... which you probably already have for making car body repairs.
Thanks for the pictures Bill!
I'll see if I can hack one together using some scrap, or see if there's a junked tach out there with that piece still attached.
I see you're in Madison Wis. Why not stop by World Wide Imports and visit with Peter Caldwell. He likely has one lying around.
I always thought that strip was part of the inductance loop and the tach wouldn't work without it. Course my tach's seldom worked anyway!
Kurt
Kurt
I am fairly confident that I have run those tachs without the clip... at least on the bench. Regardless, if you cannot find one they are a simple formed part that you can fabricate yourself if necessary. If nothing else I would want the clip to support that plastic cable holder.
My tach isn't working without it, but it could be something unrelated as I've never actually seen it work.
I always thought that strip was part of the inductance loop and the tach wouldn't work without it. Course my tach's seldom worked anyway!Kurt
I checked with Peter awhile back and he didn't have any at the time. Amazing considering the vast stockpile he has there. :smile:
Well, Doug is probably right, I'm just working on an assumption. Shouldn't be hard to make one.
Kurt.
Just a note. A mechanic lost mine and made a new one out of brass. When I complained that the tach didn't work he realized that it must be made from steel as it is the core of a transformer with the Tach innards and the outer loop. Works now.
Thanks for the information. I still remember seeing one of them work without the metal clip but there may have been other factors involved since it was a bench test. I would definitely want the clip to support the wires and it's good to know that changing from brass to steel made the difference in getting one to work!
