Quick question on setting fast idle/balancing carb
livinginthepast
Hey there,
I'm still tweaking, trying to get the carbs set up just right - H1s on 60 BE.
I'm curious how you all set the fast idle. I'm getting pretty damned proficient in quickly balancing the carbs, still struggling with the mixture (not sure why I have to back off the mixture nuts so far to get a decent mix - but maybe I'm not interpreting the manual correctly).
So the fast idle screw, as those who have been following my education in carbs, has been giving me trouble. The issue with holding the screw in place was in fact the spring. But I have a more pressing question. What is the correct procedure for setting up the front carbs two idle adjustments? I've just been playing it by ear - as my manual really doesn't say anything about it.
Oh, one other thing with the needles. I had to tweak the needle position (recessed into the piston body slightly), but I was wondering how these needles are intended to be positioned. These are standard GG needles (moss 374-095). I started by positioning them flush with the bottom of the piston. Shouuld I have pushed them all the way in to the piston?
Thanks!
Roger
Bronze
SU Needles should be flush with the bottom of the piston. That you have them slightly recessed indicates that your jet is possibly too high? Though that doesn't quite gell with your writing about backing off the nuts so much, I must say.
The purpose of the nuts is to adjust the height of the jet, and hence the mixture strength. When you back them off, you lower the jet, if I interpret you right. Are you sure the jet is descending when you do that? Sometimes the choke (rich mixture adjustment for starting) mechanism can foul up the adjustment of the jet height if it's too "tight".
You should set the mixture with the engine warmed up and the choke completely slackened off, and the car running at a fast idle. Then back off the slow-running screws so you achieve the normal idle you want.
Then you can tighten up the choke mechanism, making sure it doesn't affect your idle setting - the fast idle screw should be backed off.
With the engine stopped, pull the choke and adjust the fast idle screw so it's just opening the throttles a bit. You may have to play with it a bit to get it how you want it.
Roger
Bronze
I should have said that the step in the needle should be flush etc., etc......
livinginthepast
livinginthepast
Hi Roger,
Thanks for this.
I suspect there are other, undiagnosed issues that need addressing. I'm getting inconsistent results, there's some stumbling on acceleration that I can't tune out, the mixture seems to need constant attention (just when I think it's about right, I check it again and it's lean, etc.)
I think I'm just going to drive it for now while there's some summer left and then ask for more experienced help in the fall :smile: I had hoped to master this particular skill (SU adjustment) this summer, but it doesn't look like its going to happen!
Thanks again for your help!
BillW
JPSmit
Bill, try tightening everything up that could let in air - manifold, carbs etc. sounds like a vacuum issue
V
vagt6
Bill, "read" your spark plugs: what do you see??
Lots of carbon fouling? Ideally there should be some carbon deposits, but not excessive.
What do they look like?
Don't let the termonology mess with you, fast idle screws do one thing and one thing only, set the idle speed of the choke, if you didn't use the choke, they don't even have to be there.
livinginthepast
livinginthepast
The plugs seem to indicate that I'm running lean, although these are brand new plugs and there are only about 5 miles on them, so I'm not sure how revealing the very light white deposits are going to be. Cyl 3 tells me I have some other issue (wet/oily fouling - I've got 156 compression in that cylinder, so I'm not sure what's happening there).
Thanks!
livinginthepast
livinginthepast
I need to check all this again. On Saturday I tightened down the carbs to manifold, but I did not check the bolts on the intake manifold. Now, I thought that I could spray down the manifold to head mating points to check for leaks, but someone told me that's not going to tell me much...so I don't know if that was a waste of time or not.
Then, while looking at the manual again, I read that the carbs don't need to be tightened much more than the torque it takes to flatten the lock washers, and that too tight risks distorting mating surfaces...so I went back and loosened a little.
Yeah, it's been a little nuts.
livinginthepast
livinginthepast
Thank you, that's one of the overarching questions I had.
BillW
Roger
Bronze
BillW
Yes, that's what I meant to indicate. Guess I didn't do it well enough!
Bayless
Stumbling on acceleration can also be caused by too thin or not enough oil in the carb dash pots causing a lean condition.
JPSmit
Re: Quick question on setting fast idle/balancing
:iagree: I had marvel mystery oil in and it was too thin - things improved with engine oil
livinginthepast
livinginthepast
I'm using ATF. I'll change to engine oil and see if that makes a diff. Thanks!
livinginthepast
livinginthepast
The good news is that the BE finally seems to be running well (well, as good as possible considering all the miles :smile:
It just took some patient tweaking. I did tighten up the intake manifold and then managed to smooth out the idle by turning out the mixture a little more on the rear carb. It now accelerates smoothly and idles at a reasonable speed. It's certainly not perfect, and I'm not convinced that I *should* have to turn out the mixture nuts as far as I had to, but I'm not going to complain - it's running good and there's plenty of summer (and fall) left.
Thanks everyone for your input. I've learned a lot these past few weeks.
RickB
Hey Bill, at least it's not dumping gas like mine.
BillM & I tried to work on them, I ended up nursing the car back home.
Taking his advice I've removed the HS2's from my parts car, pulled the intake manifolds and am ready to swap.
It's amazing how much larger HS2's are than H1's... At first I thought I could just unbolt the carbs and swap them over... No way.
I took a wire wheel to the "new" heat shield, then painted with anti-rust then with high temp black. I'll be ready to assemble tomorrow - weather permitting!!
bugimike
Rick, not only larger, but nicer to fiddle with too IMHO! :wink:
livinginthepast
livinginthepast
RickB said:
...It's amazing how much larger HS2's are than H1's... At first I thought I could just unbolt the carbs and swap them over... No way.
Good luck with the swap! Keep me informed. Once all the cars are reasonably dependable, all us spridget drivin' local yokels should go for a drive... but not too far away from the tools - ha! :smile:
bugimike
WHAAAAAAT!!! You don't carry tools WITH you??? :jester:
RickB
What I found that I was most impressed by was how clean the old carbs were (inside).
They were from my MK1 Midget parts car, it had the original air cleaners on with intact filters so nothing could get inside for all the time it's sat (at least 20 years).
The pistons move freely, the chokes operate smoothly, the insides are pristine.
On the outside they are dirty & ugly, but inside like brand new.
The paint on the heat shield is dry so when I get home tonight I should be able to bolt the HS2's on and see if they work.
I'm stopping by the store to get some blue Permatex, an inline fuel filter and some new spark plugs. Hopefully tonight the little red one will be back in business. :wink:
T MGB Quick question about something that don't really matter just want to know. MG 9
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
S MGB 1980 MGB quick question MG 2
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
J General Tech Quick Dist question. TR3/4 vs Heralod Triumph 12
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
S TR6 Quick TR6 alternator question Triumph 6
M Quick tachometer wiring question on a '65 Spridgets 10
Willie_P Quick question: rear diff TR 3/4 Triumph 6
RAC68 A Quick Question [Clutch Master Seals] Austin Healey 2
MCNX_BFF Quick catch-up and trailer question Triumph 8
skelly Quick question from a newbie Spridgets 10
PatGalvin Captive nuts?? quick question Triumph 7
JPSmit Quick Spark plug question Spridgets 10
Sarastro Quick dumb transmission question Spridgets 9
T Quick fuel pump question - mounting angle MG 3
T TR4/4A TR4a retrofitting of roll bar - quick question Triumph 1
bigjones HS4 - quick question MG 6
JPSmit Quick HS4 Question MG 2
T don't have my book, quick torque question Triumph 5
JPSmit Quick Transmission question Spridgets 2
L A quick question for you UK/European LBCers Spridgets 0
Jim_Gruber Quick Carb Question Spridgets 16
bigjones Quick alternator question Spridgets 16
M TR2/3/3A Quick TR3 Question .Trans cover color Triumph 6
D Quick Question C to F Restoration & Tools 4
JPSmit Quick Carb Question Spridgets 2
theleisure quick clutch question Spridgets 10
T Quick 1275 question on a Mini motor Spridgets 2
tosoutherncars HEEELP! Quick soft top question Spridgets 7
T TR4/4A Quick question on TR4 battery Triumph 7
JPSmit Quick question #2 Emergency Brake Spridgets 1
Stewart Quick wiring question MG 6
cmacmillan TR6 Quick question on Haynes for TR6... Triumph 3
J TR4/4A Quick TR4A wiring question Triumph 6
jlaird Quick question Spridgets 5
jjbunn Quick Speedo Question Triumph 14
JPSmit Quick Question - rear hub torque Spridgets 4
mlarnoldTR6 Quick question Triumph 2
RickB MGB Quick tire size question - MGB MG 10
JPSmit Very Quick Question - rear oil seal Spridgets 2
P Quick Coil Question. Triumph 3
JPSmit Quick rear brake question Spridgets 56
T A quick silly Crypty question. Triumph 3
Webb Quick Alternator Wiring Question Triumph 3
Trevor Jessie Quick question...really [about line fitting] Spridgets 14
tosoutherncars Quick question - 1500 wiring for coil Spridgets 7
tosoutherncars QUICK QUESTION - manifold bolts Spridgets 3
Sarastro Just a quick, dumb generator asssembly question Spridgets 2
JPSmit Quick Spring Question Spridgets 10
