TR6 Questioning a Freeze Plug
SherpaPilot
I have a 72 TR6. While my cylinder head remains at the machine shop being overhauled, I decided to do some preventive maintenance on the block. While cleaning up the engine, I noticed a slight leak from a freeze plug on the right side. After a little research and YouTube watching, I successfully removed four plugs from the right side of the block. Two plugs are apparent on the left side; behind the distributor and near the forward end of the block.
According to the usual parts vendors, these are indeed freeze plugs but I am concerned about the one behind the distributor. Can anyone tell me if this is a freeze plug? I have attempted to remove it but it seems more difficult than expected. I only hope I didn't screw up my block. As usual, any helpful advice is greatly appreciated. Thanks
mrv8q
Wow, that bullfire.net site is a terrific site for the TR6 folks!
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
Marvin Gruber Auto Zone $15 freeze plugs Austin Healey 3
F Brass freeze plugs BJ8 Austin Healey 4
tomshobby Have you checked your anti-freeze? Spridgets 1
Rob Glasgow Brass Freeze Plugs Austin Healey 7
Rob Glasgow Sealant for freeze plugs Austin Healey 3
Boggsy64 MGB Freeze plug removal MG 7
M Healey 100-4 Freeze Plugs Austin Healey 1
J Core plugs/freeze plugs Austin Healey 7
TR6oldtimer TR6 Casting plugs aka freeze plug size TR6 Triumph 6
lbc_newbie Brass freeze plugs for 1275... Spridgets 20
DNK freeze Plugs Triumph 8
T TR2/3/3A TR3 head core plug [freeze plug] Triumph 6
tahoe healey Anti-freeze Austin Healey 10
tony barnhill '85 XJ6 Losing Anti-Freeze Jaguar 21
2wrench Tapping in the freeze plugs pics Triumph 1
B Freeze plugs? MG 4
HEALEYJAG Popped freeze out plug 100 le mans Austin Healey 3
I TR6 Freeze [casting] engine plugs, 69 TR6 Triumph 8
martx-5 TR2/3/3A Freeze Out Plug...TR3 Triumph 3
Tinkerman TR2/3/3A 3A freeze plug on the back of the head. Triumph 4
B Leaky Freeze Plug Austin Healey 33
P freeze plug blew out MG 27
S Anti Freeze mixture Austin Healey 3
T Starter Motor Freeze? Triumph 2
P Freeze Plug Blues Austin Healey 12
Morris Grrrrrrrrrr! Stuck freeze plug! Spridgets 21
Morris Freeze plugs Spridgets 2
A TR6 TR6-freeze plugs , Gasket , Oil pump, Questions? Triumph 2
miranda anti-freeze?? Austin Healey 2
4 T-Series TD Freeze plugs MG 0
C MGB New plug wires and distributor cap MG 10
CARSINC Spark plug thread size Spridgets 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Carlbanan56 MGB Manifold plug MG 5
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Spark plug inspection Triumph 5
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
S MGB mystery wiring plug MG 2
Bocaray TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
PAUL161 T-Series Odd spark plug encounter! MG 10
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Spock TR6 Transmission Plug Triumph 4
D TR2/3/3A Plug Leads Triumph 12
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
K TR2/3/3A Testing spark plug wires..... Triumph 11
B TR4/4A Oil Drain plug size Triumph 14
