Shucks, is all cleaned up now. Ready to assimble, and yes the clutch fork was in correctly.
Oil pump can is behind the flywheel.
As both the dust cover and the clutch slave cover where soggy with oil and the clutch slave its self, running from the lever hole, it just has to be an over fill somehow. However, I had no problems before, this just happened on this engine rebuild and reinstall.
Quite frankly if it was not the tranny I am at a complete loss and will run the engine out of the car, but I will put some dye in the engine first just to make sure.
