Jack, if you have any scraps of the carpet left over, I would try experimenting. Brake cleaner should work to remove the fluid, but may react with the dye in the carpet. Alcohol, maybe.
I hope you have some leftovers to play with!
Jeff
Anything you use Jack, I would try in a small, out of the way spot first to make sure it doesn't affect the dye in the carpet! I find that 3M Adhesive remover is a good cleaning agent for many kinds of spills/stains and usually color-safe (though not always!!)
When brake fluid is involved, I usually try alcohol. Try it on an inconspicuous spot but I've never had aproblem with it on carpet. Not the drinking kind, that's for after the spot is gone.
Jack, just a thought, the alcohol is for you, then when you get your stain removed, and the weather cools, drain the system and go synthetic. This solves the paint and stained carpet issues.
