When hooking up wires I attached the power for the fuel pump to the keyed switch along with the white wires. That is post 10 on the switch, does that sound right to you guys.
Sounds correct, i.e., with the white wires.
However, on my ignition switch the white wires are hooked up to the "IG" 'post'. On the back of the switch the 'posts' should be marked "IG" (white wires), "S&T" (red wires), "A" (brown/blue wire), and "H" (blue wire).
You know Jack, I was thinking that you might be reading IG as a 10! hehe! That's the kind of thing my old eyes would do too!! I would think a 15 to 20 amp fuse would be OK, but if you have good connections and a good ground there should be no prob.!
