As per my other post, Ms Triss is finally up on jacks to take care of some leaks. I had to put 4-5 oz of oil in the diff to compensate for the lovely spray pattern all around the universal joint. I know the seal is leaking but, as I prepare to replace it, a couple of questions.
1. When I installed this seal I didn't use permatex or anything like that - should I have?
2. My mechanic says that seals can sometime leak from the middle not the outside - ie between the spinning shaft and the inside circle of the seal. Has anyone experienced this? and can I do anything about it?
3. I could only get the nut on the pinion torqued to 140 lb instead of 200 lb - could this be problematic?
any other ideas?
thanks all
any other ideas?
thanks all
