Bruce_B
Just put in the starter motor I purchased from Rivergate now that the motor/5speed trans is in the car.
Folks who have done this - do you find that the cable going to the pull/starter cable gizmo is crushed against the engine? Seems like it will work but what about the heat of the engine?
Also...which wire do you attach to the other post (more of a spade) on the starter? I assume it's the ignition switch, but haven't looked yet at which wire to use of the ignition switch.
As always..all help appreciated.
