Jim_Gruber
Attempting to retorque the Head on my 948. My manual says all three nuts should be torqued to 46 pounds. But does that include the rocker pedestal nut that takes a 1/2" socket. I took all of those up to 35 lbs so far. I'm thinking those 1/2" nuts in the center should not be torqued to 42 lbs. Can someone please confirm before I snap one. BTW those 1/2" nuts if they go all the way into the block were not at 25 lbs even. Could account for low readings on # 2 and #3 Cylinders.
Torque Settings
Cylinder Head Nuts Plain 42 Ft/lbs
Rocker pedestal nuts 25 Ft/lbs
Torque Settings
