my 59 bugeye w/ 1098 engine and dgv weber carb is hard to start...w/ the clutch in it takes a lot longer to start than if i don't push the clutch in...also when i get the car started w/ the clutch pedal untouched then go to push the clutch pedal down, the engine cuts out...i have to rev the engine as i put the clutch inorder not to stall out...this seems to only occur when the engine is cold...anyone have any ideas as to why pushing the clutch pedal in effects the engine this way...thanks
