TR6 Purchased a second TR6
TRED
Just a bit excited, won a bid for a 71 TR6 from a car charity.
Body looks quite solid, but the rest of the car is a mistery.
Pick it up tomorrow, its missing one wheel, the brake pedal go's straight to the floor and I didn't even get to try and start it. Sure will be nice if the drive train works without total rebuilds.
DougF
Congratulations. Sounds interesting. Let us know more as you sort things out.
MadRiver
Bronze
That's awesome! Keep us posted on progress, and let's see some pics!
rooster
tdskip said:
Good man! Now go find a 3rd, and 4th and so on.
Send pictures when you can!
What you really need is a different one for each day of the week. Make sure they are different colors so you can tell them apart!
T
TRED
Great news so far, opened the trunk and found a brand new top for the car. Looks like the car has some wiring issues and so far doesn't turn over but I put it in 4th gear and gave it a push by hand and the motor turned right over. Has what looks like a good duel exhaust system and even the frame looks good.
Front rotors are rusty but look good and the pads are thick.
Gas smells like varnish and the carbs are gummed up, but the last tag on the plate is 1999 so thats to be expected.
Wonder if I can drive it next Thursday to the Triumph club meeting? I have a week off.
Any good write up's for cleaning up my carbs?
Thank Ed
AngliaGT
They have a Triumph club in Minn.?
Is that the Frostbite Falls Chapter?
- Doug
T
TRED
- Doug
Yes there is a club in Minnesota, based in the twin cities its called " Minnesota Triumphs"
More good news talked with the last owner and he nicely answered some questions. Motor only has about 50 miles after a complete pro rebuild and a new clutch.
The reason that he quit driving the car was a wire burned up under the hood. I found the burnt wire and it looks like a few other wires are disconnected.
Got the starter working and the compression was about 190 across the board.
Wow sometimes things are great.
philman
should be arrested for having too much fun....
John_Mc
TRED said:
Have a wiring article for a 71 TR6?
I don't know if you're aware of this resource, but https://advanceautowire.com/ has good accurate wiring diagrams. Click on "Stock Schematics" on the left hand side and then scroll down and you'll see downloads for "TRIUMPH TR250-TR6" and that will allow you to download diagrams in PDF format. It was a real lifesaver to me insofar as the diagrams I had in the Hayne's Manual were entirely inaccurate.
T
TRED
Thanks, thats just what I needed, this site is a real help.
Can't wait to hear this thing run and it was way back in 1987 when I last drove my 69 TR6 in stock form. This is going to be a real treat.
John_Mc
And don't forget to post some pictures! We like pictures!
T
TRED
And some pictures
In the lot missing the two front wheels and tires, with a shredded top.
The last owner did a nice job with the engine bay, but the blue needs to go!
And two pictures with the new top and the beat up paint buffed out.
T
TRED
Took two weeks since I won my car in the auction, but tonight another TR6 is back running. Seemed like a bit of a fight but I didn't plan to give up, need to see how it go's on the road tomorrow.
What did it take?
Rebuilt carbs
Pulled out the tank and shook it around with a bit of gas and a piece of chain inside, either I didn't have any sparks or it was to rich to explode.
Blow a bunch of stuff out of the fuel lines with carb cleaner and air.
Replaced all of the rubber on the fuel system and most of the pollution stuff too.
The last owner had cooked the wires inside the dist. so I replaced the wires, and thankfully I pulled the advance plates to find the advance weights were all stuck, some PB Blaster and a bunch of working the weights back and forth and they are moving nicely now.
I believe the car had been sitting for 4 years and with what is I believe a very low mileage engine I didn't want to start it without first priming the oil system. I pulled the dist and the other plate to get to the pump drive only to say, I don't have anything to drive the pump. But my son says just notch out a socket, so one notched 9mm later the pump was spinning counter clockwise and the oil gauge was reading 75 PSI. Road trip tomorrow!!
LarryK GT6 Fresh purchased GT6 Triumph 11
S TR2/3/3A purchased a box of tr3 parts this weekend, Triumph 1
Got_All_4 TR6 Newly purchased poor quality timing gear Triumph 5
R MGB-GT Just purchased Tuned for sea level, but I live at 7500', running rich MG 7
hondo402000 TR6 TR6 knobs purchased on ebay Triumph 9
J Just purchased an 84 280i from the UK TVR 15
robdmau Just purchased a 1965 Austin Healey Sprite... Spridgets 26
robdmau Just purchased a 1965 Austin Heley Sprite... Austin Healey 7
E TR4/4A New Comer with a recently purchased TR4a Triumph 16
obsesstoration Just purchased 63 former SCCA racer in NJ MG 24
Got_All_4 Any one purchased a 4 way hazard switch from VB Triumph 6
S TR6 Just purchased my first TR6 Triumph 19
T TR6 TR6 Tires - Purchased Coker Redlines, Very Happy Triumph 1
E MGB Just purchased 79 MGB MG 8
S TR2/3/3A welders have a second Triumph 5
DocDup1 TR4/4A Second Gear Bushing Triumph 6
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
Basil Second Telluride Spotting at Costco Spotted 0
O TR4/4A tr4 pops out of second gear on deceleration Triumph 13
S Issue with second gear slipping out... Austin Healey 12
D Lilly second time running... or trying Austin Healey 8
GTP1960 Here's one worth a second look. Other Cars 1
gbtr6 TR6 Top Cover On, won't go into first or second Triumph 6
S TR2/3/3A Well onto the second half Triumph 2
J T-Series Clatter in second gear only? MG 1
I adding a second fuel pump Austin Healey 16
Basil Lotus and Jags second try Spotted 3
H second guessing myself-oil thrower question Austin Healey 2
T TR4/4A Second gear hard to shift into on first try Triumph 10
W pops out of second gear on acceleration Austin Healey 12
M MGB Second MGB Off Production Line and First LH MGB [GHN3L/102] MG 3
Triumph_TR4_Girl TR4/4A Second Hand Copy of Original Triumph TR4 Triumph 1
B Second picture. I don't quite get this yet Triumph 1
N What to buy, second try MG 26
K Second hand spoked rims Triumph 18
L Popped out of second gear! Austin Healey 4
W Second Motor, looking to rebuild it Triumph 16
tinman58 Second thing to check Triumph 14
L Difficult to engage second MG 4
R Need a Second Opinion Spridgets 17
Marvin Gruber XKE second opinon Jaguar 28
bthompson I've lost second gear!! Spridgets 95
R My second crash and first in a car. Austin Healey 9
Sopwith_Camel from last summer my second to last day in norway Spridgets 8
JPSmit second verse same as the first [almost] Spridgets 13
Brosky eBay Hardtop, second go around Triumph 5
hondo402000 TR6 TR6 rebuilt the Front Calipers, second time Triumph 2
Dadandson My 1974 Midget took Second!! Spridgets 6
Brosky TR6 Second chance on Special Order white/blue TR6 Triumph 8
